Forum Index : Microcontroller and PC projects : Microchip - Free Freight
During March Microchip are offering free freight on purchases from Microchip Direct. To claim this you need to use the coupon code FreeShipmD during checkout. Generally Microchip are the cheapest source for their own products and as far as I can tell this applies to everything they sell. They ship via international courier so it is good value. EDIT: Damn, I did not spot that Peter has beaten me to the announcement!!! Geoff Geoff Graham - http://geoffg.net |
| Lou Senior Member Joined: 01/02/2014 Location: United StatesPosts: 229 |
Thanks Geoff Good info, I always order Microchip Direct... have not seen Peter's post yet. Lou Microcontrollers - the other white meat |
just browsing through the microchip site, there seem to be a load of device i've not spotted before. for example: PIC32MX170F512L an MX170 in a 100-pin package, 512k of flash, 4 SPI channels. these 100-pin MX170's seem, on the face of it, to be more capable than the MX470, though the core not as fast: http://www.microchip.com/wwwproducts/Devices.aspx?product=PI C32MX170F512L the datasheet is 60001290C.pdf this would give an MX170 with the possibility of VGA output and SD card support. could be i've not just looked in the right places before, or are these new? cheers, rob :-) addendum: but, of course, just realised that with only 64k of RAM, the video resolution will be limited... |
The new chips are coming thick and fast. It will be difficult to support them all so for the moment I am concentrating on getting Peter's port for the MX470 integrated with the extra features (USB & SD Card). Geoff Graham - http://geoffg.net |
Geoff wrote: I am concentrating on getting Peter's port for the MX470 integrated with the extra features (USB & SD Card).
Great news, thanks Geoff. Lou Microcontrollers - the other white meat |
| Zonker Guru Joined: 18/08/2012 Location: United StatesPosts: 772 |
Wow..! Awesome news... So, does this mean... Maybe using let's say the 1.8" or the 2.4" touch displays that we are prototyping with, and use their onboard SD card sockets as the MM SD card. The display command/data port is SPI, the touch controller is SPI and the SD card is SPI.... Nice... So, Layout a 470 based MPU interface board that has the RTC, USB, and power supplies to make a quick, cheap ready to go module... This should be doable... (hope so)
"Shhh!! Be quiet!"
That is exactly what i am working on. Displays still not arrived yet so i am getting a bit impatient. Microblocks. Build with logic. |
