Local Time 15:35 24 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MX170 4.6b, problem with pin(0) ?
PicFan
Posted: 01:34am 11 Mar 2015
Hello,
Maybe is this a bug, please look the Modification and the Output in the 2. Example ?
TEST 1: Works OK !
REM TEST Analog Input !
spgPin = 23
SETPIN spgPin, AIN
PRINT ""
PRINT "Display Analog-Value"
A = PIN(spgPin) / (pin(0) / 1.2) Example in 4.6b Manual P29
PRINT "V="A
end
Output on MMEDIT Chat
> RUN
V= 2.46089
TEST 2:
spgPin = 23
SETPIN spgPin, AIN
PRINT ""
vRef = PIN(0) Modification
A = PIN(spgPin) / (vRef / 1.2)
PRINT "V="A
end
1. Output on MMEDIT Chat
> RUN
Display AnaloÁ
Micromite MkII MMBasic Ver 4.6b
Copyright 2011-2015 Geoff Graham
2. Output on MMEDIT Chat, only if you click 2. RUN under 1 Sek.
> RUN
V= 2.46089
TEST 3:
spgPin = 23
SETPIN spgPin, AIN
PRINT ""
DO
vRef = PIN(0)
PRINT "V="A
PAUSE 2000
LOOP
end
> RUN
Display AnaloÁ
Not DO . . . LOOP !
If you change the PAUSE to 500ms, maybe ist works ?
Thanks and best regards
Wolfgang
Posted: 02:21am 11 Mar 2015
  Quote  PRINT "V="A
should be: PRINT "V=",A
PicFan
Posted: 05:06am 11 Mar 2015
  matherp said
  Quote  PRINT "V="A
Hello Matherp !
This is not the problem, please look the Output from Example 2 + 3 or test the following:
spgPin = 23
SETPIN spgPin, AIN
PRINT ""
vRef = PIN(0)
PRINT "END"
> RUN
Display AnaloÁ
False Output for "Display Analog-Value" and no Output for PRINT "END" !!
vRef = PIN(0) this Command make the problem, the System is "RESTARTED" !
If you click "RUN" after a short delay (< 1 sek.) maybe it works, after a long delay (2-3 sek.) it works not.
Thank you !
WolfgangEdited by PicFan 2015-03-12
Justplayin
Posted: 09:34am 11 Mar 2015
I have two MX170's that I purchased directly from Microchip at the same time. One "reboots" when I try to read the voltage from Pin(0), the other returns a value. During 4.6 beta testing I reported the problem as a possible bug but no one else experienced the problem. Since one works and the other doesn't, I assumed the problem is a defective MX170. I still use the questionable chip for on a breadboarding since everything else I've tried seems to work normally.
--Curtis
Posted: 10:05am 11 Mar 2015
  Quote   One "reboots" when I try to read the voltage from Pin(0), the other returns a value.
Interesting, reading the internal reference voltage doesn't work at all on the MX470 due to a silicon issue. Sounds like it might be marginal on the MX170 as well.
PicFan, what happens if you use CPU 10 to reduce power consumption? This is the issue on the MX470
Posted: 02:52pm 11 Mar 2015
When I was developing the MM2 I also had intermittent issues with reading the internal reference but they "magically" went away and I never found the reason. It could because the chips are marginal and the problem only shows up in certain conditions (Vdd, temperature, etc).
I was never happy with the PIN(0) concept and this just makes it worse - I may have to remove this feature from the next Micromite version.
PicFan
Posted: 02:17am 12 Mar 2015
Hello Geoff !
So it works without problems:
PRINT PIN(spgPin) / (PIN(0) / 1.2) The example in Manual MK2 4.6b Page 29 !
A problem is if you make a variable:
vRef = PIN(0)
Wolfgang
The change from CPU 40 to CPU 10 have no effect, the same problem.Edited by PicFan 2015-03-13
Posted: 05:00am 12 Mar 2015
  Quote  I may have to remove this feature from the next Micromite version.
In the STM32 code I've implemented OPTION VCC nnn
This is then used to scale both the ADC and the DAC to correct the absolute readings. Obviously, this doesn't solve the problem on a battery supply which is changing but works well for a normal supply where the voltage may not be exactly 3.3V but is unlikely to change much.
Justplayin
Posted: 10:07am 12 Mar 2015
@Geoff - Don't know if this helps... If I read from any analog input pin first, pin(0) functions correctly from then on.
spgPin = 23
SETPIN spgPin, AIN
PRINT ""
A = PIN(spgPin)
B = PIN(0)
Print A, B, PIN(0)
end
--Curtis
disco4now
Posted: 07:47pm 17 Mar 2015
  Justplayin said   @Geoff - Don't know if this helps... If I read from any analog input pin first, pin(0) functions correctly from then on.
--Curtis
I am seeing the same on MX170 with 4.6B.
Will reset unless another pin is read first.
F4 H7FotSF4xGT
panky
Posted: 04:54pm 18 Mar 2015
100 pin 470 does not appear to support pin 0 - I get invalid pin error whether with a pre-ceeding analog pin read or not?
panky
Edit: Running a 100 pin 470 from WW with beta 10
Edited by panky 2015-03-20
disco4now
Posted: 06:10pm 18 Mar 2015
The 470 code i.e. beta 10 does not support the pin(0) function as it caused reboots so was not coded into MMbasic, gives you the invalid pin error
F4 H7FotSF4xGT
panky
Posted: 08:20pm 18 Mar 2015
I see also (I think, be gentle boys if I'm in fairyland) that in the 100 pin 470 beta10 that the Pin() and Setpin commands use the actual physical pin of the chip.
Is this true for the 28 and 40 pin 150s? What of the 170s? ... or is it just part of the beta part of the 470s?
Would this not cause issues with portability? My understanding is that the original Maximite pin numbering was from 1 to 20 and not related to the physical pin of the PIC chip? Thus Pin 1 on the Maximite was actually physical pin 21 on the 26 way connector and some other number on the chip itself.
I can't see any reference in the uMite doco or anywhere else that this has now changed.
Am I missing something here?
Doug.
Edit: Found the reference to using physical pin numbering in the 4.6b manual. Curious Geoff, why the change as now in i/o, there is no portability from chip to chip?.
Doug.
Posted: 10:23pm 18 Mar 2015
@panky
With all the MicroMites (MX150, MX170 & MX470 versions) the physical pin number has always been the reference used in code. I can't be 100% certain as to the new ARM MicroMite port though as still not yet played with one!
The MaxiMite was different i.e. physical pin did not correlate to number used in code (as you stated).
Hope this clears things up.
Posted: 04:04am 19 Mar 2015
--Curtis
has anyone had a look at the MX170 source code to see what 1-time initialization is performed when reading an analog input (pins 2, 3, etc) that is not carried out when reading pin(0)? on the face of it, this seems a fairly straightforward bug to nail down.
rob :-)
Posted: 01:33pm 19 Mar 2015
Reading from pin(0) might look like reading from any other pin to the BASIC programmer but it is different internally.
I will investigate but I believe that the issue with reading the internal reference is hardware related.
Posted: 03:55am 20 Mar 2015
it would be a great shame to lose the pin(0) function, as it enables the micromite to work as a semi-accurate analog data collector without need for external reference components.
if the answer were as simple as having to always read an analog input before each access to the bandgap reference, would a crude workaround be to re-jig the analog version of the pin() command thus:
value = pin( n [, scale])
thus pin(2) would return the analog input at pin 2 assuming a 3v3 supply (as is currently implemented), while pin(2,1.0) would return the value scaled using the bandgap reference. using a scale value other than 1.0 would allow the returned value to be corrected for both variances between bandgap references on individual MX170's, as well as any input divider at the pin.
rob :-)
