Forum Index : Microcontroller and PC projects : Interrupts
In MM basic if I have an interrupt eg: SetPin 6, INTH,XXXX Can I execute the interrupt in software with Pin 6=1 Pause 5 Pin 6=0 Would I need a pause. Paul. "It is better to be ignorant and ask a stupid question than to be plain Stupid and not ask at all" |
Just do this: [code] SetPin 6, INTH, MySub .... 'call the sub when needed from software MySub ..... SUB MySub 'Do your stuff here when an interrupt on pin 6 occurs OR when it is called from software. END SUB [/code] Microblocks. Build with logic. |
Does not the interrupt have to end with 'Ireturn' or is it OK to branch to a defined sub. Read the manual on interrupts and could not find anything. Paul. "It is better to be ignorant and ask a stupid question than to be plain Stupid and not ask at all" |
| disco4now Guru Joined: 18/12/2014 Location: AustraliaPosts: 1151 |
Its OK to call a SUB, use END SUB and not IRETURN to end it. The 4.6 Manual details it with the SETPIN command description. (there are two sections for SETPIN one after the other in the command section. Gerry F4 H7FotSF4xGT |
For new programs it would be better to use [code] SUB MySub ... END SUB [/code] instead of the old way [code] MySub: .... return 'or ireturn [/code] The old way is more open to subtle errors as a program can execute code in a subroutine when not all code paths are terminated and obviously your case where a interrupt routine has to be used from code. Microblocks. Build with logic. |
I am confused - are we saying it is now possible to terminate an interrupt with 'End Sub'?? WW |
Yes, that was introduced together with defined functions and subroutines. I think the micromites had that from the beginning, the maximite in later versions. It might be good to remove that from the manual and always use defined subroutines for interrupts. Microblocks. Build with logic. |
Excellent point. The old code (calling a label) can be left in but deprecated. Geoff Geoff Graham - http://geoffg.net |
I missed that one - always used 'iReturn'!! Guess it is time I re-read the manual
Thanks all that's a big help. Paul. "It is better to be ignorant and ask a stupid question than to be plain Stupid and not ask at all" |
Grogster![]() Admin Group Joined: 31/12/2012 Location: New ZealandPosts: 10046 |
It DOES depend on what you are doing. If you KNOW FOR A FACT that the code will only EVER be called by an interrupt, then IRETURN is fine, I would think. Having interrupts call a subroutine that ends with END SUB is a nice combination though, if you need to be able to call the same code without it having to be summoned from an interrupt. Only problem I see with calling a sub from an interrupt, is that if the code happens to be in that very same sub, when the interrupt calls it again - would that perhaps not cause some odd and difficult to track bugs in code operation? Smoke makes things work. When the smoke gets out, it stops! |
