Forum Index : Microcontroller and PC projects : Micromite : CFuncGen4PIC32 : V1.0.28
| G8JCF Guru Joined: 15/05/2014 Location: United KingdomPosts: 676 |
Hi I have just posted the latest release of CFuncGen4PIC32 at http://www.g8jcf.dyndns.org/mmbasicmkii/ The main changes/fixes in V 1.0.28 are : 1) Added NoTabs check box - check if you do NOT want any tab characters in the CFunction source output - useful when pasting Cfunction source code directly into MMBasic's in-built VT100 text editor 2) Removed need to specify the development tool, ie no longer dependent on MPLab or MPLabX 3) Found and eliminated the defects which prevented Clean and Build in MPLab from working properly - CFuncGen was keeping directories opened needlessly, now, it just accesses the file(s) in the directory and then leaves the directory immediately afterwards. 4) Tidied up the formatted CFunction source output You will need to uninstall the existing version of CFuncGen before installing CFuncGen4PIC32 - The old version is still available for download at the same site in case you want/need to revert to the original version. I would be very interested to hear feedback from any CFunction authors regarding this new version - or indeed about anything else of course :) Many thanks Peter The only Konstant is Change |
| twofingers Guru Joined: 02/06/2014 Location: GermanyPosts: 1773 |
Hi Peter, highly appreciated! Seems I have to begin to write CFunctions. Thanks a lot!
Michael ‚My name is Ozymandias, king of kings Look on my works, ye Mighty, and despair!‘ Nothing beside remains. Round the decay Of that colossal wreck, boundless and bare The lone and ... |
Hi Michael I thought it was you who first reported the problem with pasting into MmBasic VT100 editor with leading tabs
I always use MMEdit, so I never had that problem, but it was so easy to do, I added in NoTabs option Looking forward to seeing your first CFunctions Peter The only Konstant is Change |
This must be a mix up! Sorry, I can't remember.
Hope this will happen soon!
Ah, it may have been @plasma in that case Apologies for the mix up Peter The only Konstant is Change |
