Forum Index : Microcontroller and PC projects : PCB track width calculator...
Grogster![]() Admin Group Joined: 31/12/2012 Location: New ZealandPosts: 10046 |
Hi folks.
While looking around the net, I found this neat web-based PCB track width calculator: Track Width Calculator What's neat about it, is that it is very flexible and allows easy calculation of track widths depending on current, distance, trace length and pour thickness. Many different units including inches, mm, mil etc. Calculated both internal and external track widths. I like this page! Smoke makes things work. When the smoke gets out, it stops! |
I think you are now a fully qualified 'PCBoholic'
(good find though!!) |
I needed to be able to pass about 3-amps through some tracks, so wanted to make sure I was making them big enough. I was using the "1mm per amp" rule, so the tracks were 3mm wide, which seems to be plenty according to the calculator. Smoke makes things work. When the smoke gets out, it stops! |
