Local Time 09:49 24 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MIgrating from maximite to micromite
CarlRanson
Posted: 11:22pm 07 Jun 2015
Hey all,
So I've finally gotten back to playing with my *mites and am at the point of trying to run on the micromite hardware.
Correct me if I'm wrong, but the micromite (as sold by silicon chip) doesn't have a B: or A: drive at all. So it only has "memory" for one program.
The question is how do I get my program from the maximite SSD to the micromite's memory
Thought I'd ask before trying to trick teraTerm into "typing" out the program.
Thanks,
CR
jman
Posted: 11:25pm 07 Jun 2015
Hi
Upload with TeraTerm using xmodem
Press F11 from the console then click file transfer xmodem send
CarlRanson
Posted: 11:48pm 07 Jun 2015
Thanks, John.
I dare say you saved me a fair chunk of time there.
CR
panky
Posted: 12:31am 08 Jun 2015
CR,
Better still, (imho) is to use TassyJims MMEdit - because there are quite a lot of differences in commands, to be able to view your code with commands etc colour coded and the ability to download and run works just great. Just upload all your Maximite programs from the SD card into the PC then open them in MMEdit. Also included is the ability to move files backwards and forwards from the Maximite so if you wanted, you could connect both machines to MMEdit.
Cheers,
Panky
Posted: 12:42am 08 Jun 2015
I fully agree with panky on this one - definitely worth using TassyJims brilliant MMEdit as it is so much easier for transferring programs from your MaxiMite to a MicroMite.
And yes, you are correct about the memory containing just one program (with no drives). Yet another reason for using MMEdit.
WW
CarlRanson
Posted: 12:25am 17 Jun 2015
having a little trouble getting I2C to work on the micromite.
I'm seeing the normal hex 71 address I expect followed by a few extra bits of data.
It almost looks like its using 10bit addresses, or its cutting off most of the bits following the address.
Anything obvious that I'm missing here?
Posted: 01:39am 17 Jun 2015
What are you trying to talk to?
EEPROM?
CarlRanson
Posted: 05:33pm 17 Jun 2015
The same displays I've had working just fine on the maximiteV1.
I got some more kits this morning, I'll report back once I've built one of them up.
CarlRanson
Posted: 12:08am 26 Jun 2015
So it turn's out I'm a big dummy...the I2C device wasn't powered so the ack bit wasn't being sent back.
For the Record: On the Rigol DS1054 I2C decoding this shows as a write block with the correct address shown followed by a skinny block that just has a question mark.
Hopefully that will help someone who follows
