Local Time 09:03 24 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MM+ Execution Speed
atmega8
Posted: 01:09am 11 Jul 2015
in Mmbasic/ Micromite we had some "Numbers" about Execution Speed of Basic Lines.
I think it was about 15000 - 30000 Lines/Second depending on the CPU Speed.
Any Idea how fast the MM+ will be with 120 MHz CPU Speed?
Do we have Benchmarks?
THX,
Dietmar
Posted: 01:49am 11 Jul 2015
No benchmarks yet, but if you can show me some code to run for a benchmark, I can run them on the MM+ I have here, and post the results. I would expect the results to be quite good compared to the 40MHz MM2. I can only test at 100MHz for the moment - waiting for the 120MHz spec chips to arrive before I can run 120MHz. Geoff's video was done at 100MHz so I understand - he will correct me if I am wrong about that.
Posted: 02:33am 11 Jul 2015
See this thread for MM+ Speeds
I get exactly the same results on the recently released firmware the same as Geoff posted previously at 120MHz
Posted: 02:41am 11 Jul 2015
Thanks matherp - not sure how I missed that one......
Posted: 04:51am 11 Jul 2015
I use an unofficial and simple benchmark which gives:
- Micromite MkII at 48MHz is 27716 lines/sec
- Micromite Plus at 120MHz is 49019 lines/sec
