Forum Index : Microcontroller and PC projects : MM2(+): SHT11 temperature/humidity
| matherp Guru Joined: 11/12/2012 Location: United KingdomPosts: 11903 |
The SHT11 is a combined temperature and humidity sensor from Sensiron The sensors are fairly available and sometimes show up on ebay very cheaply. They can be soldered (carefully) to an 8-pin SOIC/DIL adapter The sensor uses a two pin interface with a clock and a data pin. This makes it easy to bit-bang from Basic. This code is converted from some Picaxe code but the floating point capability of the Micromite makes the calculations much easier. The clock can be pulled up to VCC with a 4K7 resistor but the internal MX pullups seem to work fine. The sensor constants in the code assume a 3.3V power supply but the datasheet referenced above gives alternate values for other supply voltages option explicit option default none const SCK_PIN=1 'pin to connect SHT11 clock const DAT_OUT_PIN=2 'pin to connect SHT11 data const fullclock=2 'length of clock pulse in msec const halfclock=fullclock\2 const rtemp=3 'code to start temperature conversion const rhumidity=5 'code to start humidity conversion 'SHT11 magic numbers const d1=-39.66 const d2=0.01 const c1=-2.0468 const c2=0.0367 const c3=-1.5955e-6 const t1=0.01 const t2=0.00008 ' DIM float temperature pin(SCK_PIN)=0 setpin SCK_PIN,dout setpin DAT_OUT_PIN,din connectionreset do temperature=read_temp() print temperature,read_humidity(temperature) pause 2000 loop end sub connectionreset ' routine to reset the chip local integer i for i = 1 to 10 pin(SCK_PIN)=1 pause fullclock pin(SCK_PIN)=0 pause fullclock next i return sub transstart() ' routine to start a transaction setpin DAT_OUT_PIN,dout' set the clock and data as outputs pin(SCK_PIN)=0: pin(DAT_OUT_PIN)=1 ' clock low and data high pause halfclock pin(SCK_PIN)=1 ' clock high and data high pause halfclock pin(DAT_OUT_PIN)=0 ' clock stays high, data low pause halfclock pin(SCK_PIN)=0' clock goes low, data stays low pause fullclock pin(SCK_PIN)=1 ' clock high, data stays low pause halfclock pin(DAT_OUT_PIN)=1 ' clock stays high data high pause halfclock return function read_temp() as float 'routine to return current tem,perature local integer i,j transstart() writebyte(rtemp) waitcomplete() i=readbyteack() j=readbyte() read_temp=d1+d2*(j+(i<<8)) end function function read_humidity(temp as float) as float ' routine to return current humidity local integer i,j local float SO,RHlin transstart() writebyte(rhumidity) waitcomplete() i=readbyteack() j=readbyte() SO=j+(i<<8) RHlin=c1+c2*SO+c3*(SO^2) ' read_humidity=(temp-25)*(t1+t2*SO) * RHlin end function sub writebyte(b0 as integer) 'outputs the byte in b0 to the SHT11 local integer i setpin DAT_OUT_PIN,dout' set the clock and data as outputs pin(SCK_PIN)=0: pin(DAT_OUT_PIN)=1 ' data high and clock low if (b0 and 128)=0 then: clocklow() :else :clockhigh(): endif if (b0 and 64)=0 then: clocklow() :else :clockhigh(): endif if (b0 and 32)=0 then: clocklow() :else :clockhigh(): endif if (b0 and 16)=0 then: clocklow() :else :clockhigh(): endif if (b0 and 8)=0 then: clocklow() :else :clockhigh(): endif if (b0 and 4)=0 then: clocklow() :else :clockhigh(): endif if (b0 and 2)=0 then: clocklow() :else :clockhigh(): endif if (b0 and 1)=0 then: clocklow() :else :clockhigh(): endif setpin DAT_OUT_PIN,DIN,pullup i=readbit() return sub clocklow() pin(SCK_PIN)=0: pin(DAT_OUT_PIN)=0 ' set data low pause halfclock pin(SCK_PIN)=1 ' set clock high, data stays low pause fullclock pin(SCK_PIN)=0 ' set clock low, data stays low pause halfclock end sub sub clockhigh() pin(SCK_PIN)=0: pin(DAT_OUT_PIN)=1 ' set data high pause halfclock pin(SCK_PIN)=1 ' set clock high, data stays high pause fullclock pin(SCK_PIN)=0 ' set clock low, data stays high pause halfclock end sub function readbit() as integer' generate a clock pulse to read a bit into b1 pause halfclock pin(SCK_PIN)=1 ' set clock high pause halfclock readbit=pin(DAT_OUT_PIN) 'read data pause halfclock pin(SCK_PIN)=0' set clock low pause halfclock END FUNCTION function readbyteack() as integer 'inputs a byte , send ack setpin DAT_OUT_PIN,DIN,pullup if readbit() then: readbyteack=128: else :readbyteack=0: endif if readbit() then: readbyteack=readbyteack OR 64 : endif if readbit() then: readbyteack=readbyteack OR 32 : endif if readbit() then: readbyteack=readbyteack OR 16 : endif if readbit() then: readbyteack=readbyteack OR 8 : endif if readbit() then: readbyteack=readbyteack OR 4 : endif if readbit() then: readbyteack=readbyteack OR 2 : endif if readbit() then: readbyteack=readbyteack OR 1 : endif pause halfclock setpin DAT_OUT_PIN,DOUT clocklow setpin DAT_OUT_PIN,DIN,pullup END FUNCTION function readbyte() as integer 'inputs a byte , send ack setpin DAT_OUT_PIN,DIN,pullup if readbit() then: readbyte=128: else: readbyte=0: endif if readbit() then: readbyte=readbyte OR 64 : endif if readbit() then: readbyte=readbyte OR 32 : endif if readbit() then: readbyte=readbyte OR 16 : endif if readbit() then: readbyte=readbyte OR 8 : endif if readbit() then: readbyte=readbyte OR 4 : endif if readbit() then: readbyte=readbyte OR 2 : endif if readbit() then: readbyte=readbyte OR 1 : endif pause halfclock pin(SCK_PIN)=0' set data goes high with pullup pause halfclock pin(SCK_PIN)=1 ' set clock high, data stays high pause fullclock pin(SCK_PIN)=0 ' set clock low, data stays high pause halfclock END FUNCTION sub waitcomplete() 'put timeout code in here if required l: pause 20 if pin(DAT_OUT_PIN)<>0 goto l end sub |
