Forum Index : Microcontroller and PC projects : Interesting multi-function USB host
| matherp Guru Joined: 11/12/2012 Location: United KingdomPosts: 11903 |
Just found this I have no information other than that on the website but it looks like a great way to interface specific USB devices to a MM2 The various software modules are uploaded using a bootloader (DS30) which I have used before and this means no programmer (PicKit etc.) is needed to swap between the various images |
I have one of those, but I have not put it to use yet. Micromites and Maximites! - Beginning Maximite |
| plasma Guru Joined: 08/04/2012 Location: GermanyPosts: 437 |
Great info , thx matherp |
By the way, these guys also supply a lower cost pre-programmed PIC chip by itself for use on your own PCB/breadboard. Available in DIP, SOIC, and SSOP packages. To view details about these, click on matherp's link in the original post above, then on the HobbyTronic's page, click 'Related Products' and scroll down . . . PS - The guys are one of my regular suppliers and I find their products very good quality |
It is a great gadget. This is one of these times whn I say to myself "why didn't I think of that". Geoff Graham - http://geoffg.net |
Grogster![]() Admin Group Joined: 31/12/2012 Location: New ZealandPosts: 10044 |
Perhaps this could be the solution to the USB Keyboard concept that was floating around the threads for the MM+? Smoke makes things work. When the smoke gets out, it stops! |
| Chris Roper Senior Member Joined: 19/05/2015 Location: South AfricaPosts: 280 |
Or a Micromite implementation on the PIC270MX with the different USB modes loadable via CFunctions. http://caroper.blogspot.com/ |
| BobD Guru Joined: 07/12/2011 Location: AustraliaPosts: 935 |
that's what I thought when I first read about it but it ends up being expensive. The card would probably cost AU$35 to 40 landed in OZ then you need a keyboard. |
Or a Micromite implementation on the PIC32MX270 with the different USB modes loadable via CFunctions. EDIT: Duplicate due to Internet error, my apologies, I can't even edit the erroneous post above. http://caroper.blogspot.com/ |
Chris, It's a forum implementation that edit capability is closed when there is a subsequent posting. Bob |
Hmmmmmmm..............good point........ Perhaps not. Smoke makes things work. When the smoke gets out, it stops! |
I just took that card to the checkout and it was AU$42.60 delivered and then there would be card or Paypal fees on top. So looking like $45 all up. |
Sounds like WhiteWizzard micromite.org has a relationship with the supplier. Why not PM him to see if he can do something on postage and/or bulk shipping |
| Positron Newbie Joined: 09/08/2015 Location: ArgentinaPosts: 20 |
Hi all !, I bought the HobbyTronics USB Host Keyboard to Serial chip in DIP package and works ok for standard ASCII input, I' m using it with a wireless mini keyboard. The problem arises when you try to use it as the Console input, as it does not implement the proper VT100 escape sequences recognized by the MMite built-in Editor ( arrow keys, function keys, etc). So it doesn't work as a full PS/2 keyboard replacement
The firmware is not open source and the key mappings are not user reconfigurable, at least in the current version. As Grog suggested in another post adding a simple PIC with a serial- in serial-out translation table could solve the problem, but in the end it will be a 3 chip solution, kinda' overkill ! |
| boss Senior Member Joined: 19/08/2011 Location: CanadaPosts: 268 |
Good morning Gents, I purchased roughly 9 month ago similar (if not the same) device on eBay for $10. The device was made by renowned Chinese company so I didn't expect any serious problems. The reality was shocking. Only what works was read/write to USB stick, but there was stick capacity limit (I think 4GB max) if I remember well. Unfortunately very limited number of Dell and HP keyboards and mice was properly recognized. Btw I received full source code written by Microchip, but in C and buggy. If someone is interested in the source code I could to find it.There was also enclosed a written permission to change and modify this source code. I believe that source code origin might be Microchip library. Regards Bo |
... Btw I received full source code written by Microchip, but in C and buggy. If someone is interested in the source code I could to find it.There was also enclosed a written permission to change and modify this source code. I believe that source code origin might be Microchip library. Regards Bo Hi Boss, I could check that source and see I can remap the escape codes , could you Send me a link, Thanks ! |
@Positron I'll do it ASAP and send the file to you via PM. Bo |
Sounds interesting, I have a few PIC24FJ64GB002's sitting on my bench and would love to try the code. I am not much good with C though so may have to wait and see what Positron can do with it. I had a look at the Microchip Library's but, as with most Microchip Documentation, the comments were way over my head and the code somewhat obfuscated at times. Cheers Chris http://caroper.blogspot.com/ |
@ Chris Roper Neither I am. I think this is challenge for some of C gurus on this forum. If you are interested in code, please send message with your email address to my PM. Bo |
