Forum Index : Microcontroller and PC projects : Servo command on 4.7b23
sagt3k![]() Guru Joined: 01/02/2015 Location: ItalyPosts: 313 |
Hi Geoff I use "servo" command on firmware 4.6 with no problems. In new version 4.7b23, Are there differences between these versions? Thanks |
No, the commands are the same in both. But be aware that B23 is a test version and there may be bugs. Geoff Graham - http://geoffg.net |
