palcal Guru Joined: 12/10/2011 Location: AustraliaPosts: 2052
Posted: 08:37pm 10 Aug 2015
When I use the CLS (colour) command the screen clears but the background will not change to the colour specified in the command. I'm sure it worked in a previous version.
Paul."It is better to be ignorant and ask a stupid question than to be plain Stupid and not ask at all"
matherp Guru Joined: 11/12/2012 Location: United KingdomPosts: 11903
Posted: 09:06pm 10 Aug 2015
It definitely works:
are you using the correct syntax?
CLS RGB(RED)
if you do "CLS RED" then RED is just a newly created variable which will be initialised to 0 (black) - problem avoided if you always use OPTION EXPLICIT
You can also set the default colours with:
COLOUR RGB(RED),RGB(BLUE)
this then means CLS will write a blue background and other drawing functions (e.g. BOX) will default to red; text will be red on blue.Edited by matherp 2015-08-12
Posted: 11:28pm 10 Aug 2015
Thanks I was using CLS Red
Silly me I used the correct syntax before
Paul.
Edit..... Why didn't I get a syntax error, that would have pushed me in the right direction.
PaulEdited by palcal 2015-08-12"It is better to be ignorant and ask a stupid question than to be plain Stupid and not ask at all"
