Local Time 06:01 24 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : 5" TFT display for Micromite + ?
f1fco
Posted: 11:14pm 28 Aug 2015
hello,
is it this 5" display OK for the Micromite + ?
http://www.ebay.com/itm/5-inch-TFT-LCD-Display-Module-800x480-Touch-Panel-SD-For-Arduino-uno-R3-DUE/281674264426?_trksid =p2047675.c100005.m1851&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D1%26asc%3D33097%26meid%3Dfc2205ce99624895a108e44e e2d200f1%26pid%3D100005%26rk%3D1%26rkt%3D6%26sd%3D331562629033
if, yes, I order one
thank you for answer
Pierre
73s de F1FCO
Posted: 11:22pm 28 Aug 2015
Should be fine, looks exactly like the one I have.
The only issue with this version is that it gets the power for the backlight off the 3.3V supply so you need to make sure your 3.3V regulation is adequate (the LED pin is only used as a switch for the backlight).
I find the display is rather dim, certainly not as good as either my 4.3" or 7" displays.Edited by matherp 2015-08-30
f1fco
Posted: 04:06am 29 Aug 2015
what is the "right" model ?
with external power supply (5v ?) for the back light
an ebay link ?
thank you
Pierre
73s de F1FCO
