Forum Index : Microcontroller and PC projects : TONE command on MicroMite ?
| f1fco Senior Member Joined: 18/03/2012 Location: FrancePosts: 155 |
hello, TONE command exist on Maximite software output is a "pure" sinus I make DTMF tones : 2 simultaneous frequencies (not exactly the same level : I mix the right and left level in a 10Koms potentiometer) combination of frequencies 697, 770, 852, 941 and 1209, 1336, 1447, 1633 Hz is it possible to have the same function on the Micromite ? the PWM command is a square wave a CFunction perhaps ? or make a "strong" filter for the square wave ? what components ? thank you for help Pierre 73s de F1FCO |
what is the "precision" in frequency with PWM command ? with TONE command, 1 Hz is possible (on the DTMF frequencies) 73s de F1FCO |
Yes, the TONE command is not in the Micromite and I doubt that a CFunction could be used to replicate the function. It may be something that could be added to the firmware but it will take some research. At the least it would share the same output pins as PWM 1A and 1B. Does anyone else have a need for this function? Is it an urgent need? Geoff Geoff Graham - http://geoffg.net |
TONE (or BEEP) with as many of the following parameters: Freq, Duration, Volume; this would be a 'nice to have' for my requirements |
| cosmic frog Guru Joined: 09/02/2012 Location: United KingdomPosts: 311 |
Yes Tone with volume would be great! |
Slight modification based upon what used to be common on 80's home computers: TONE channel,freq,duration,volume I know the MM+ is NOT a home computer - just suggesting this for consideration if ever Geoff does implement a TONE type command. In the above, Channel represents Left, Right or Both (i.e. stereo). With this command it was possible to create some great music for integrating into programs (not quite polyphonic, but certainly better than just a standard 'beep'. WW |
| Justplayin Guru Joined: 31/01/2014 Location: United StatesPosts: 330 |
Yes! Being able to output even some simple sounds would be great. I have been thinking about building a MicroMite powered "pill-minder" to remind my mother to take her various medications on time. --Curtis I am not a Mad Scientist... It makes me happy inventing new ways to take over the world!! |
| hitsware Guru Joined: 23/11/2012 Location: United StatesPosts: 535 |
PWM is very usefull for audio output. (As implied by initial post) |
That 'TONE' was usually a squarewave... |
No urgency at all, but it's nice the way TONE will sweep so smoothly . |
| Chris Roper Senior Member Joined: 19/05/2015 Location: South AfricaPosts: 280 |
Here is a Program I wrote a couple of years ago on the Original MicroMite on the MX150 Chip, it should work on the MM Mk2 as well. It scans a 1 Octave Keyboard and outputs 2 Tones on the 2 PWM Channels. I was emulating an electric Organ so the code is set up specifically to generate harmonic effects by mixing the two outputs. It made some very pleasant music, or should I say it could if I was actually musically inclined. With a Suitable Amp, I used powerd PC speakers, it makes a passable church organ effect. [code] Keypad KeyCode, KP_Int, 21, 22, 23, 3, 18, 25, 2, 7 ' 1 Octave keyboard setpin 6, AIN ' Gate Duration setpin 9, DOUT ' Mode LED1 setpin 10, DOUT ' Mode LED2 setpin 14, DOUT ' Mode LED3 setpin 15, DOUT ' LFO PIN(15) = 1 LFO_F = 0 ' LFO1 Off LFO_D = 50 ' LFO1 Default Pulse Width Duty = 50 ' Osc2 Default Pulse Width Chorus = 1 ' Chorus Effect Off (Osc2 tracks Osc1) Octave = 4 ' Keyboard range 261.63Hz - 523.25Hz (Middle C) Do SETTICK 200, LFO_Int, 3 ' Low Frequancy Oscillator ' Map keyboard to musical notes IF KeyCode = 3 then MyNote = 1 ' C IF KeyCode = 2 then MyNote = 2 ' C# IF KeyCode = 1 then MyNote = 3 ' D IF KeyCode = 20 then MyNote = 4 ' D# IF KeyCode = 9 then MyNote = 5 ' E IF KeyCode = 6 then MyNote = 6 ' F IF KeyCode = 5 then MyNote = 7 ' F# IF KeyCode = 4 then MyNote = 8 ' G IF KeyCode = 21 then MyNote = 9 ' G# IF KeyCode = 22 then MyNote = 10 ' A IF KeyCode = 8 then MyNote = 11 ' A# IF KeyCode = 7 then MyNote = 12 ' B IF KeyCode = 11 then MyNote = 13 ' C if MyNote > 0 then ' Note Key Played if Trigger then 'Start the Gate Gate = 250 * PIN(6) + 10 ' Turn off Trigger Trigger = 0 ' Send Debug info once per Note ? "note1" Freq1 " Chorus" Chorus " Chord" Chord " Octave" Octave " Duty" Duty " Gate" Gate endif if Gate > 0 then ' Note is currently Playing freq2 = 30.87 * ((2^(1/12)) ^ (MyNote + Chord * 12)) * 2^(Octave - 1) freq1 = 30.87 * ((2^(1/12)) ^ MyNote) * 2^(Octave - 1) if freq2 > 20 then pwm 2, freq2 * Chorus, Duty if freq1 > 20 then pwm 1, freq1, 50 Gate = Gate - 1 Else ' Gate is Closed, Stop the Note pwm 1, STOP PWM 2, STOP MyNote = 0 endif endif Loop LFO_Int: PULSE 15, 100 IRETURN KP_Int: ' a key press has been detected Trigger = 1 IF KeyCode = 23 then if shift = 1 then Chorus = Chorus - 0.0025 elseif shift = 2 then Duty = Duty - 5 elseif shift = 3 then Chord = Chord - 1 else Octave = Octave - 1 if Octave < 0 then Octave = 0 endif Trigger = 0 endif IF KeyCode = 10 then if shift = 1 then Chorus = Chorus + 0.0025 elseif shift = 2 then Duty = Duty + 5 elseif shift = 3 then Chord = Chord + 1 else Octave = Octave + 1 if Octave > 7 then Octave = 7 endif Trigger = 0 endif IF KeyCode = 0 then shift = shift + 1 if shift > 7 then shift = 0 port(9,2,14,1) = shift Trigger = 0 endif IRETURN [/code] You may be able to use my Tone Functions from that. Cheers Chris http://caroper.blogspot.com/ |
thank you to all for answers I have the real answer but I hope... if Geoff can add the TONE command, I can wait... a (long) time to make a "syntesizer", the code of Chris Roper is very useful square wave is an advantage for harmonics effects finally, can you help me for values of a filter ? R and C to quasi transform sqare in sinus (a low pass filter) Pierre 73s de F1FCO |
Here Ya Go .... |
| skyv Newbie Joined: 14/03/2015 Location: AustraliaPosts: 14 |
Hi hitsware The link doesn't appear to be working for me. Could you please check. Thanks skyv |
Works fine for me Cheers Chris p.s. Talking of links here is a good description of generating pure Sine Waves with a PIC Micro. It will give you a good idea of what is involved and how to filter it. You may even end up with a useful tool :) http://www.romanblack.com/onesec/Sine1kHz.htm http://caroper.blogspot.com/ |
Thanks Chris I'll check my computer settings skyv |
http://www.learningaboutelectronics.com/Articles/Low-pass-filter-calculator.php |
thank you for links I have forget my electronics laws... I will try with 1OOO or 820 ohms and 100nF and see the result on my scope Pierre 73s de F1FCO |
| jimbotron Regular Member Joined: 27/11/2013 Location: AustraliaPosts: 50 |
Hi Pierre, Try using different filters for the different pins. One of the pins will be generating signals under 1KHz and the other will be higher. Use a lower cutoff frequency for the low frequency pin to get better sine waves. |
hi Jimbotron, judicious suggestion, you are right, I try it thank you, Pierre 73s de F1FCO |
