Local Time 04:22 24 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Can a CFunction create a VT100 emulation?
MMAndy
Posted: 09:14am 21 Sep 2015
We are trying to figure out how to create
a "Tera Term" like program on our MM+ Explore 64
Embedded Basic Laptop. Then we would use this
VT100 terminal to serially communicate with other
MicroMites. Just think - no windows 10 problems,
no reset problems, no serial driver problems,
no PC and above all no network connection.
Edited by MMAndy 2015-09-22
MicroBlocks
Posted: 03:25pm 21 Sep 2015
Has already been done.
http://geoffg.net/terminal.html
MMAndy
Posted: 03:39pm 21 Sep 2015
Correct, it has been done for the ASCII video terminal board.(PIC32MX250)
Is there a CFunction VT100 emulation for the SSD1963 7" TFT display, MM+ Explore 64 with keyboard and console serial port?
Posted: 03:43pm 21 Sep 2015
You would not need a CFunction, it would be easier to write it in BASIC.
MMAndy
Posted: 07:07am 22 Sep 2015
Well beyond our programming capabilities.
We were hoping to use our Embedded Basic Laptop not only as a VT100 terminal but as a firmware programming terminal which will "cut the cord" and not use a PC altogether except for firmware hex file access. More research on-going ...
Edited by MMAndy 2015-09-23
