Local Time 04:21 24 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Extend SPI range?
Justplayin
Posted: 09:44am 23 Sep 2015
I'm trying to figure out a way to connect a large string of the 8x8 LED matrix modules. Problem is the SPI connection fails after about 8 modules daisy chained together. Any suggestions what would might work as a signal booster/repeater/buffer/driver (pick your terminology)? I'm looking at connect about 28 modules to start with.
Thanks,
Curtis
Posted: 10:10am 23 Sep 2015
Try one of these or just duplicate mosfet circuit but use the same voltage on each sideEdited by matherp 2015-09-24
Justplayin
Posted: 10:18am 23 Sep 2015
Thanks for the suggestion! I bought some of those awhile back and never used them. I'll give it a try. All I have to do now is find them!
--Curtis
Posted: 04:52pm 23 Sep 2015
Hi Peter, Curtis,
  matherp said   Try one of these or just duplicate mosfet circuit but use the same voltage on each side
HaHa I just emailed Curtis this morning with exactly the same device..
What do they say about great minds??
Posted: 04:57pm 23 Sep 2015
Curtis,
You would only need one of these I reckon as the Din is cascading through the Max7219 so should effectively be boosted/buffered EVERY module... The CS and CLK signals are paralleled so would need the buffer.
Justplayin
Posted: 07:13pm 23 Sep 2015
  bigmik said  You would only need one of these I reckon as the Din is cascading through the Max7219 so should effectively be boosted/buffered EVERY module... The CS and CLK signals are paralleled so would need the buffer.
I tried the one converter I had immediately on hand and had moderate success with 12 modules. Looked great when it was working! But, in the end my setup was still unstable. There are some issues I need to address such as I had everything plugged into a cheap breadboard, was using lots of crappy jumper wires and the converter had some really long leads already soldered om to it. I'm going to try again after I find my other converters and set the whole thing up a little more "in-line". If needed, I don't mind using a couple set of converters to boost the signals along, they're cheap.
--Curtis
