Local Time 04:20 24 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : I2C question
kiiid
Posted: 09:56am 23 Sep 2015
Is there any way to enable the PIC32's built-in pull-ups on the I2C lines, and have the lines configures for I2C operation in MM+ with them?
http://rittle.org
Posted: 10:08am 23 Sep 2015
Try setting up I2C as normal and then poking the CNPUB register to turn on the pullup on b8 and b9
Poke &HbF886158, &H300
UNTESTED!!!!!!
Posted: 06:10pm 23 Sep 2015
Hi Kon, Peter,
That is a good idea, I assume these pullups will be `weak' ones so external may still be required but they may be fine for some devices at slow speeds.
maybe the I2C open command can be added to by something like
I2C OPEN speed, timeout, PU
Posted: 02:41pm 25 Sep 2015
  bigmik said  I2C OPEN speed, timeout, PU
Great idea, I will add it to the list.
