Forum Index : Microcontroller and PC projects : R61505V display driver
| kiiid Guru Joined: 11/05/2013 Location: United KingdomPosts: 671 |
Has anyone ever made a R61505V-based TFT operational from a MM? I see there is a good selection of those in AliExpress, and they are relatively cheap and round. http://rittle.org -------------- |
| Zonker Guru Joined: 18/08/2012 Location: United StatesPosts: 772 |
A round TFT..? Awesome... This would be perfect for gauge displays... Where did you see them..? |
AliExpress There are pieces on eBay as well http://rittle.org -------------- |
| viscomjim Guru Joined: 08/01/2014 Location: United StatesPosts: 925 |
THOSE ARE AWESOME!!!! It would be great to have that library. |
| matherp Guru Joined: 11/12/2012 Location: United KingdomPosts: 11903 |
Can't see any with any sort of breakout board. The bare flexible PCB makes things too hard to develop with as you never know if problems are software or hardware. |
From the same link to AliExpress http://rittle.org -------------- |
I've often wondered how the pixel addressing works on these round TFTs. The spec says 220(RGB)x220 (whatever that means!). Where do you think pixel x=0,y=0 is? Could it be the centre? Or is it the top left
Seriously, has anyone played with one of these ever to enlighten me on pixel x,y referencing
WW |
There are two possible ways to interpret this: 1. The circle is embedded into an imaginary square, and all pixels which are not within the circle are not physically implemented. That means the pixel with coordinates (0,0) actually does not exist on the screen. 2. The entire circle is a one-dimentional helical line like a CD with (0,0) being in the centre. Which one of these is in reality - I am yet to find out. I have a nice idea for a project with round display, but apparently they are all using either ST7789 (the smaller ones), or R61505V (the bigger ones), and neither of these is currently supported by MM http://rittle.org -------------- |
