Local Time 01:36 24 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MM+ WIN 10 USB BUG
atmega8
Posted: 07:33am 06 Nov 2015
No solution from Microsoft...
http://blogs.windows.com/windowsexperience/2015/11/05/announcing-windows-10-insider-preview-build-10586/
November Upgrade
Any news from you, Geoff?Edited by atmega8 2015-11-07
Posted: 07:59am 06 Nov 2015
It works fine now on W10. As long as you are receiving updates you should find it is now working.
It is actually better than in W7 as you no longer have to remove and replug the connection with teraterm closed to see the com port.
See this thread
atmega8
Posted: 08:31am 06 Nov 2015
wow, will test immediately....
let you know
atmega8
Posted: 08:52am 06 Nov 2015
Powered over USB.
See serial device com 20 with MS driver version 10.0.10240.16401 date 21.06.2006.
No connection....., reset, plug/unplug...
Was the Baudrate important ????
Posted: 09:17am 06 Nov 2015
  Quote  Was the Baudrate important ????
38400 as normal on a newly flashed chip. The driver version is exactly the same as I've got. I've just tested powering over USB and all good.
atmega8
Posted: 09:34am 06 Nov 2015
Mea Culpa,
38400 Baud.
I had the opinion ( read it somwhere) that the Baudrate doesn' matter for USB Connections...
it basically works !!, Hurra!
Reset or plug/unplug doesn't work.
That needs a restart of terraterm and press of enter key.
Same result as white wizzard has reported:
"Power for E64 was not externally powered (i.e. supplied through USB cable) and after firing up TT I could select a COM port. Then had to press enter to get the 'Welcome' message (showing B36).
However, if I do a soft reset (with WATCHDOG 1), or a hard reset (press the reset button), then the connection is lost. In this scenario I just 'Disconnected' within TT, and then established a New Connection. "
Thank you !
MicroBlocks
Posted: 08:43pm 06 Nov 2015
I made a usb-serial in a pic16f1455 and can tell that USB does not care about a baudrate. When you change the baudrate in TT then the USb-Serial software is instructed to setup the outgoing hardware uart part of the soloution to that specific baudrate.
When there is no other hardware to communicate with and the data stays in the software there is no point in having a baudrate.
I don't know how the implementation in the PIC32 is, but i suspect when there is no hardware uart there is no specific need for a baudrate.
atmega8
Posted: 11:20pm 06 Nov 2015
can confirm, that the configured Baudrate in TT doesn't matter.
Tested it in TT and Putty.
My post above was wrong, i flashed the wrong firmware ;-(.
You get the mmbasic prompt, no matte if Baudrate is set to any value...
THX
