Local Time 01:37 24 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : I2C2
palcal
Posted: 08:32pm 11 Nov 2015
Trying to use I2C2 on a 100 pinner with V4.7b37
Using the command I2C2 OPEN 100,1000 I get an error UNKNOWN COMMAND. Am I using the correct syntax, I can't find any reference to I2C2 anywhere in the manual except on the chip pinout.
Paul
Posted: 10:47pm 11 Nov 2015
Exactly the issue I had yesterday. I emailed Grogster to see if he knew the latest as even in the change logs it is not mentioned.
I did see a post from Geoff explaining that I2C2 should be in the next release but I ended up using the first I2C channel for now.
Am emailing Geoff to find out current status.
WW
Posted: 12:44am 12 Nov 2015
The story is that with the development of the I2C CFunction (included in the 5.0 distribution for the MX170) the need for the second I2C channel has largely gone away - with the CFunction you can have as many I2C channels as you want.
A second factor is that the I2C code needs to be rewritten to support a second channel (it was not written by me) and I have run out of time to do this.
So, in summary, there will not be an I2C2 but you can use a CFunction instead.
P.S The I2C CFunction refered to above will work fine on a 100 pinner with V4.7b37Edited by Geoffg 2015-11-13
Posted: 12:47am 12 Nov 2015
  Geoffg said  So, in summary, there will not be an I2C2 but you can use a CFunction instead.
Thanks for clarifying this
Will the v5.0 CFunction work as it is on both the 64pin & 100pin MM+'s? I have not looked at the code yet so sorry if this is a silly question.
WW
Posted: 12:50am 12 Nov 2015
Yes it will. BTW I edited my post while you were typing your question.
Posted: 02:00am 12 Nov 2015
@Geoffg
Can I recommend that the references to the I2C2 pins (in the 64pin & 100pin pinout diagrams) be removed from the User Manual. This will avoid any confusion to others in the future.
Will try the CFunction on 100pinner later and report any issues . . . .
WW
palcal
Posted: 10:06am 12 Nov 2015
A bit of a bummer. I designed a board and had them made using both I2C channels.
Will have to cut tracks an hard wire.
Paul.
viscomjim
Posted: 10:17am 12 Nov 2015
Palcal, can you not use those pins with the Cfunction and make your project work?
palcal
Posted: 10:59am 12 Nov 2015
It,s OK, the device connected to I2C2 is on short flying leads so I moved them directly to the I2C pins and all is working.
Paul.
Posted: 11:12am 12 Nov 2015
With the CFunction you can select the I/O pins. So why not select the pins that were going to be used by I2C2?
palcal
Posted: 01:13pm 12 Nov 2015
Thanks for that Geoff, I haven't looked at the CFunction yet but will do that.
Thanks.
Paul.
