Local Time 23:44 23 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Gas Stove burner left on - reminder
MikeO
Posted: 01:11am 12 Dec 2015
We have all left the gas stove burner on at some time . Go on admit it! Here is a fun project with a serious use. A "Gas Stove burner left on" reminder, bit of a mouth full I know.
The circuit is simple ,a uMite with 1 push button , 1 NTC sensor , 1 Piezo speaker and a couple of LEDs.
The circuit is mounted somewhere above the stove so it can measure the local temperature. The uMite reads the NTC sensor every 15 seconds and in between it goes to sleep to save the battery. It constantly adjusts and stores the ambient temperature. What it is looking for is a large change in temperature, a degree or so in the sample period . When it senses this change it goes into alarm mode and the piezo sounds which you acknowledge by pressing the button. The UMite continues to monitor the temperature and if 30 minutes passes and the stove is still on, the alarm will sound again, pressing the button will set a further 30 min period but if you have walked away and forgotten the burner hopefully it will bring you back to turn it off! If you have turned off the stove the uMite will detect the drop in temperature back to the ambient and reset the alarm. You can also reset the alarm by pressing the button during a wakeup period (every 15sec).
' ***** Stove Sensor *****
' Filename: mm2stovexx.bas
' Date: Dec 2015
' File Version:
' Written by: M.Ogden
' Function: uMite Stove left on sensor
' Last Revision:
' Target MM2
' Option Explicit
Option Default Integer
Option autorun On
Cpu 48
dim Level,newLevel,resultLevel,prealarmlevel
dim alarm, ack,increase,alarmtime
dim pin.temp=7
dim pin.redled=22
dim pin.yellowled=18
dim pin.button=16
dim pin.beep=27
dim pin.battV=6
dim pin.pwm=2
Const adcFactor=0.0032258
dim threslevel=2
'setup i/o
setpin pin.temp, ain
setpin pin.redled, dout
setpin pin.yellowled, dout
setpin pin.battv, ain
setpin pin.button, din, PULLUP
level=Cint(Pin(7)/adcfactor) 'read sensor to establish ambient level
do
adctempSensor
'If we get back here there has been a Temperature change
if Alarm = 1 and Increase =0 then 'temperature has dropped reset the Alarm
AlarmReset
goto buttonclear
elseif Increase =1 and alarm =0 then 'new alarm
alarm=1 'set alarm
acknowledgeAlarm:
soundAlarm
pause 1000
if pin(pin.button)=1 then goto acknowledgealarm
ack=1
goto buttonclear
end if
buttonclear:
if pin(pin.button)=0 then goto buttonclear
pause 1000
loop
sub adctempSensor
local x
cpu sleep 15
pin(pin.yellowled)=1
pause 50
pin(pin.yellowled)=0
'pulse pin.yellowled, 50
newlevel=0
for x=1 to 20
newlevel=newlevel + Cint(Pin(7)/adcfactor)
next x
newlevel=newlevel/20
'read sensor
If newlevel>level Then 'establish new base level
'Temperature decrease
resultLevel=newLevel-level
increase=0
Else
'Temperature increase
resultLevel=level-newLevel
increase=1
End If
if alarm =0 then prealarmlevel=level ' freeze level when in alarm
level=newlevel
Print "PreAlarmLevel:" + str$(prealarmlevel)
print "New Level / swing " + str$(level) + " / " + str$(resultlevel)
If pin(pin.button)=0 then alarmreset 'during debug change this command to END
'check if pre alarm tems have been reached if so rsset alarm conditions
if alarm=1 and level=>prealarmlevel then alarmreset
if alarm=1 then
pin(pin.redled)=1
pause 100
pin(pin.redled)=0
alarmtime=alarmtime+1
print "Alarmtime" + str$(Alarmtime)
if alarmtime>120 then repeatalarm
end if
checkbattery
Loop Until resultlevel>threslevel 'trigger when exceeding base level by threshold value
end sub
sub checkbattery
local dcv as float
dcv=pin(pin.battv)
print "Battery Level:" + str$(dcv)
if dcv <= 2.3 then
sound (100,2)
end if
end sub
sub alarmReset
print "Alarm Reset"
alarm=0:ack=0:alarmtime=0
sound (10,20)
end sub
sub repeatalarm
print "Repeat Alarm"
alarmtime=0
acknowledgeAlarm:
soundAlarm
pause 100
end sub
sub soundalarm
sound (100,10)
pause 200
sound (100,10)
pause 200
sound (100,10)
pause 200
end sub
sub sound(note,duration)
pwm pin.pwm,39*note,50
pause 10*duration
pwm pin.pwm,stop
end sub
Codenquilts
viscomjim
Posted: 03:04am 12 Dec 2015
Nice project Mike. Have you had enough time to see how long this will operate on battery power?
MikeO
Posted: 10:10am 12 Dec 2015
According to my trusty phone app around 80 days.
Mike
Codenquilts
