Forum Index : Microcontroller and PC projects : Problems with GUI SHOW
| Bizzie Senior Member Joined: 06/07/2014 Location: AustraliaPosts: 194 |
Hi all, Has anyone been able to use the GUI SHOW #ref or ALL command? Here's what I get with a simple test program :- Micromite Plus MMBasic Ver 4.7 Beta 36
Copyright 2011-2015 Geof> > OPTION LIST OPTION BAUDRATE 115200 OPTION LCDPANEL ILI9341, LANDSCAPE, 21, 22, 23 OPTION TOUCH 18, 14 OPTION SDCARD 49 > LIST Option EXPLICIT GUI DEFAULT HIDDEN Const CtrlColor = RGB(Yellow) Const BckColor = RGB(Black) Const CtrlTextColor = RGB(White) CLS Font 1,2 ' Controls for page 2 - Set date Const pg2Frm = 20 Const pg2Yr = 21 Const pg2Mth = 22 Const pg2Day = 23 Const pg2Cap1 = 24 Const pg2Cap2 = 25 Const pg2Cap3 = 26 Const pg2Max = 26 GUI FRAME pg2Frm, "Date", 0,13,MM.HRes,MM.VRes,CtrlColor GUI CAPTION pg2Cap1, "Day",10,30,LT,CtrlTextColor,BckColor GUI SPINBOX pg2Day, 150,40,140,40,CtrlColor,BckColor,1,1,31 GUI CAPTION pg2Cap2, "Month",10,90,LT,CtrlTextColor,BckColor GUI SPINBOX pg2Mth, 150,90,140,40,CtrlColor,BckColor,1,1,12 GUI CAPTION pg2Cap3, "Year",10,140,LT,CtrlTextColor,BckColor GUI SPINBOX pg2Yr, 150,140,140,40,CtrlColor,BckColor,1,15,30 GUI SHOW pg2Frm Do Loop > RUN [33] GUI SHOW pg2Frm Error: Invalid command > GUI SHOW ALL Error: Invalid command > As you can see the problem also exists at the command prompt. I can not find an example anywhere of the GUI SHOW command. Rob White |
| disco4now Guru Joined: 18/12/2014 Location: AustraliaPosts: 1151 |
Seems to work OK on Micromite Plus MMBasic Ver 4.7 Beta 37. GUI SHOW ALL --> shows all controls. GUI SHOW pg2Frm --> shows just the frame Regards Gerry F4 H7FotSF4xGT |
