Local Time 20:47 23 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : playing with Micromite and an Rpi2
plasma
Posted: 03:33pm 19 Jan 2016
some progress from my "full HD" display for the Micromite.
A Micromite sends some Commands over the serial port , the Rpi drives the Display and wraps the commands to OGL.
its funny to see some MMbasic Gfx on an full Hd Display.
the speed is ok , not much commands yet maybe much moore later.....
its only a test atm...
gtx
https://m.youtube.com/watch?v=BBT5b4pEGNg
Edited by plasma 2016-01-21
plasma
Posted: 03:43pm 19 Jan 2016
Micromite power
Frank N. Furter
Posted: 09:47pm 19 Jan 2016
Hi Plasma,
that looks interesting! Can you tell more about the code on the Mite and on the Rpi?
Frank
plasma
Posted: 05:30am 20 Jan 2016
Hi Frank ,
no problem .
on the micromite (the easy Part i use some strings with the following format
headerbytes +gfx command+ x,y,x1,y1,switch1,schwitch2,endbytes
such like :
color = 1
rect = 2
line = 3
Print #2 , header$+","+str$(rect)+","+str$(x)+","+str$(y)+","+str$(x1)+","+str$(y1)+end$
draws a Rectangle with x,y,x1,y1
on the Rpi side i use Bmx-ng a blitzmax Port for the Rpi.
Bmx-ng supports ogl,socket,sound,key,mouse etc.
so i wrote a simple parser (lame and ugly atm) and wrapped the commands.
the Goal is to port the wrapper to Android / Ios and use an old tablet as Micromite Display.
MicroBlocks
Posted: 06:45am 20 Jan 2016
Did you consider X-Windows?
That is something i am considering.
A uMite would then be the client.
plasma
Posted: 04:51pm 21 Jan 2016
next test
plasma
Posted: 04:58pm 21 Jan 2016
hmm x- windows ? i dunno Microblocks
my solution is giving the micromite or every other micro pc with an serial port a full Hd display.
so you can expand the rpi gpio with an micromite and expand the micromite with a big display.
i solved some speed issues and epand the commandset.
gtx
