Local Time 20:46 23 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MM+ V5.1 ILI9341 BUG / Hardware ???
atmega8
Posted: 07:02am 26 Jan 2016
Hello,
Micromite Explorer 64 with ILI9341.
Connected like OPTION LCDPANEL:
option lcdpanel ili9341, l, 60, 61, 62
SCK on PIN 4, SDA (SDI MOSI) on PIN5.
Voltage directly from the Explorer 64 board (GND/5Volt).
After above command, MM+ wants reboot.
After Reboot, WIN 10 enumerates no com Port, the typical windows sound, when USB Device is found is missing.
No terminalsession possible (Terraterm).
If i disconnect everything, same problem.
I can flash MM+ again, no problem.
But then the same thing happens as described.
Power Consumption 130 mA
Any Idea?Edited by atmega8 2016-01-27
atmega8
Posted: 08:12am 26 Jan 2016
Update,
another Explorer 64 board works as expected..
Search for the reason..
atmega8
Posted: 08:25am 26 Jan 2016
Strange....
i reflashed the controller, it gave a correct prompt etc., twice.
After this gui test lcdpanel worked.
Lesson learned, reflash before throwing it away.
THX
