Local Time 19:08 23 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Morse note?
Herry
Posted: 06:58pm 16 Feb 2016
In the absence of any sound, beep or tone command I am wondering if there is a simple way of generating a given note to be output to a small speaker or similar. I've seen a couple of rather complex offerings. I only want to generate one note but I will be placing this in routines that generate a) dots, b)dashes and c) a continuous note.Edited by Herry 2016-02-18
Senior?!  Whatever it says, I'm a complete and utter beginner...
OA47
Posted: 07:03pm 16 Feb 2016
Herry, not sure if I am reading your question right but PWM is your default sound producer.
GM
twofingers
Posted: 07:32pm 16 Feb 2016
Hi Herry,
this could be interesting for you: Micromite Musical Box.
There is also a Morse program for MAXIMITES. You should be able to convert this for your Micromite.
Michael
The lone and ...
Herry
Posted: 01:55pm 17 Feb 2016
OK, PWM it is. I shall work on that. I suppose I can pass parameters (arguments) with subroutines or functions?
viscomjim
Posted: 05:25am 18 Feb 2016
Hi Herry, I remembered a piece of code from a few years back on the GreatCow Basic forum that read a ps2 keyboard and did the morse code. This is a good starting point where you would have to make the obvious changes for the uMite, I just thought it was cool the way the dot and bar subs were used. Take a look and let us know how you make out on your project.
'Morse Code demonstration for Great Cow BASIC
'(c) Hugh Considine 2006-2008
'A program to accept messages from a standard PS/2 keyboard, then play
'them as morse code using a speaker.
'User Settings
#define CodeFrequency 750 'Hz
#define DotLength 5 '* 10 ms
#define DotSpace 250 ' ms
#define BarLength 25 '* 10 ms
#define BarSpace 50 ' ms
'Hardware settings
#chip 16F877A, 20
'LCD connection settings
#define LCD_IO 8
#define LCD_DATA_PORT PORTC
#define LCD_RS PORTD.0
#define LCD_RW PORTD.1
#define LCD_Enable PORTD.2
'PS/2 keyboard connection settings
#define PS2Clock PORTB.1
#define PS2Data PORTB.2
'Tone output pin
#define SoundOut PORTD.3
'Set port directions
DIR PS2Clock IN
DIR PS2Data IN
DIR SoundOut OUT
'Clear key buffer
DIM KeyLog(32)
DataCount = 0
KeyLog(1) = 32 'Space character
'Show opening message
PRINT "GCBASIC Morse"
locate 1,0
PRINT "Code Transmitter"
'Main routine
Main:
'Get a keypress
KeyIn = INKEY
if KeyIn = 0 then goto Main
'Allow time for key to be released
wait 150 ms
'if ENTER is pressed, then send message
if KeyIn = 13 then
MorseSend
goto Main
end if
'Escape - clear message buffer
if KeyIn = 27 then
DataCount = 0
for DataPos = 1 to 32
KeyLog(DataPos) = 32
next
goto DisplayData
end if
'Backspace - delete last character
if KeyIn = 8 then
if DataCount = 0 then goto Main
KeyLog(DataCount) = 32
DataCount = DataCount - 1
goto DisplayData
end if
'Otherwise, add the character to the buffer
DataCount = DataCount + 1
KeyLog(DataCount) = KeyIn
DisplayData:
'Display key log
CLS
for DataPos = 1 to DataCount
if DataPos = 17 then locate 1,0
LCDWriteChar KeyLog(DataPos)
next
goto Main
sub MorseSend
for SendLetter = 1 to DataCount
Letter = KeyLog(SendLetter)
'Numbers
if Letter = 48 then Bar: Bar: Bar: Bar: Bar '0
if Letter = 49 then Dot: Bar: Bar: Bar: Bar '1
if Letter = 50 then Dot: Dot: Bar: Bar: Bar '2
if Letter = 51 then Dot: Dot: Dot: Bar: Bar '3
if Letter = 52 then Dot: Dot: Dot: Dot: Bar '4
if Letter = 53 then Dot: Dot: Dot: Dot: Dot '5
if Letter = 54 then Bar: Dot: Dot: Dot: Dot '6
if Letter = 55 then Bar: Bar: Dot: Dot: Dot '7
if Letter = 56 then Bar: Bar: Bar: Dot: Dot '8
if Letter = 57 then Bar: Bar: Bar: Bar: Dot '9
'Letters
if Letter >= 97 and Letter <= 122 then Letter -= 32 'Convert to upper case
if Letter = 65 then Dot: Bar
if Letter = 66 then Bar: Dot: Dot: Dot
if Letter = 67 then Bar: Dot: Bar: Dot
if Letter = 68 then Bar: Dot: Dot
if Letter = 69 then Dot
if Letter = 70 then Dot: Dot: Bar: Dot
if Letter = 71 then Bar: Bar: Dot
if Letter = 72 then Dot: Dot: Dot: Dot
if Letter = 73 then Dot: Dot 'I
if Letter = 74 then Dot: Bar: Bar: Bar 'J
if Letter = 75 then Bar: Dot: Bar 'K
if Letter = 76 then Dot: Bar: Dot: Dot 'L
if Letter = 77 then Bar: Bar 'M
if Letter = 78 then Bar: Dot 'N
if Letter = 79 then Bar: Bar: Bar 'O
if Letter = 80 then Dot: Bar: Bar: Dot 'P
if Letter = 81 then Bar: Bar: Dot: Bar 'Q
if Letter = 82 then Dot: Bar: Dot 'R
if Letter = 83 then Dot: Dot: Dot 'S
if Letter = 84 then Bar 'T
if Letter = 85 then Dot: Dot: Bar 'U
if Letter = 86 then Dot: Dot: Dot: Bar 'V
if Letter = 87 then Dot: Bar: Bar 'W
if Letter = 88 then Bar: Dot: Dot: Bar 'X
if Letter = 89 then Bar: Dot: Bar: Bar 'Y
if Letter = 90 then Bar: Bar: Dot: Dot 'Z
'Misc
if Letter = 32 then wait 300 ms 'Space
next
end sub
sub Dot
Tone CodeFrequency, DotLength
wait DotSpace ms
end sub
sub Bar
Tone CodeFrequency, BarLength
wait BarSpace ms
end sub
HankR
Posted: 06:03am 18 Feb 2016
'Get a keypress
KeyIn = INKEY
end sub
This is an amazingly simple way to interface to a PS2 keyboard. High fives to the compiler designer for that feature and implementation.
Sometimes GREAT COW can be so limited in many important ways, but that part is a winner.
Thanks, Jim.
Hank
HankR
Posted: 06:10am 18 Feb 2016
  viscomjim said   I just thought it was cool the way the dot and bar subs were used.
Jim,
If you like that, you should see the various bit saving schemes that are employed for coding the dits and dahs (dots and dashes for civilians) using assembler or C.
Fun to figure out how it's done. Every Morse symbol takes up only 1 byte.
I've done this kind of minimalist encoding for ham radio balloon borne transmitters using early PIC microcontrollers.
Hank
CircuitGizmos
Posted: 07:48am 18 Feb 2016
The scheme I worked out is to encode dit as 0, dah as 1. Also leading 0 is ignored, 1 is ignored and a start bit.
Example:
S is . . .
Encoded: 00001000
Decode bit by bit from MSB
0 ignore
0 ignore
0 ignore
0 ignore
1 ignore and 'start' (next bits are real)
0 dit
0 dit
0 dit
Example:
O is _ _ _
Encoded: 00001111
0 ignore
0 ignore
0 ignore
0 ignore
1 dah
1 dah
1 dah
Example:
2 is . . _ _ _
Encoded: 00100111
0 ignore
0 ignore
0 dit
0 dit
1 dah
1 dah
1 dah
Actually, though, I encoded from LSB, so it all was backward from what is here, but it is easier to see the morse code and the encoding "forward" rather than backward.
Herry
Posted: 08:34am 18 Feb 2016
All good. It turns out to be amazingly trivial for my application. As advised it is simply eg PWM 2, 400, 50 and a loudspeaker via an electrolytic on pin 26, with of course PWM 2, STOP after the required delay! Thanks to all who replied.Edited by Herry 2016-02-19
