Local Time 18:27 23 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : programming 16F628A
palcal
Posted: 08:43pm 21 Feb 2016
Trying to program a 16F628A with my PicKit3 it connects OK but gives an error message Device ID does not match. I have checked my setting OK. I tried to program anyway but programming failed.
Any ideas.
Paul.
Frank N. Furter
Posted: 09:13pm 21 Feb 2016
Hi Paul,
is your PIC self powered? Did you use 5V or 3V3? Did you have a connection between VCC of the PicKit and your PIC?
Frank
palcal
Posted: 09:28pm 21 Feb 2016
Yes it is powered by my Bench Supply I have programmed a lot of PICs before and never had a problem. I think maybe a faulty chip, I will get another next time I go to town.
Paul.
Posted: 09:32pm 21 Feb 2016
Paul,
Sometimes the PicKit3 software will reply with this error even though the selection is correct.
Couple of things to check/try:
1: Ensure the reset pin is pulled high (10k)
2: Ensure you have a decoupling cap close to PICs power pins (100nF)
3: If in a breadboard - move circuit to a different position (cheap breadboard issue that keeps appearing on this forum!!)
If all above ok, then just try programming anyway - it may well work.
The early MaxiMites I had the Device ID error, but was able to program and successfully use the PICs.
Good luck . . . .
WW
EDIT: The debugging feature of the PicKit3 may not work with an 'incorrect Device ID'; but programming will (or should!!)
Edited by WhiteWizzard 2016-02-23
palcal
Posted: 10:29pm 21 Feb 2016
Not a Dreadboard and I tried programming anyway but it didn't work. I will look at your other suggestions especially the decoupling, I know my bench power supply is a bit dirty so I will try powering from a cleaner supply.
Paul.
Frank N. Furter
Posted: 11:05pm 21 Feb 2016
I had the same problem last week with a 12F629 - always an error message: Device ID does not match!
I tried a old board revision which worked in the past with the same 12F629 on it and got the same error!
Now I tried IPE instead of MPLAB and all was working without any trouble?!
I don't know why my MPLAB suddenly doesn't worked with my PicKit 3...
Paul, try another program (PicKit 3 standalone software, MPLABX, IPE, MPLAB) to program your chip...
Frank
paceman
Posted: 01:53am 22 Feb 2016
Paul, I flashed one of these a few weeks ago with the PiKcit3 and V2.26 of IPE - I'm using it for a capacitance meter a la Roman Black. As I remember it complained the first time I tried and then worked the second time. The supply is a good bench one.
Greg
