Local Time 18:27 23 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : ssd1306 oled I2C driver
viscomjim
Posted: 07:45am 22 Feb 2016
Can anyone confirm that the drivers referenced HERE in this thread are the latest and greatest for the SS1306 I2C oled display? And, can you use fonts with this like the other displays?
Thanks!!!!!Edited by viscomjim 2016-02-23
Posted: 08:15am 22 Feb 2016
Latest driver for the SSD1306 is here
This is the only version that integrates with the MM firmware graphics calls (text, circle etc.)
It only support SPI displays, not I2C, and only works on the 28 and 44-pin parts
It is possible to make this work on the 64-pin. However, I can't make it work on I2C as I don't have access to the I2C routines from a Cfunction and I2C is too hard to drive direct.Edited by matherp 2016-02-23
