Local Time 18:28 23 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Problems with GUI HIDE ALL
Bizzie
Posted: 12:27pm 24 Feb 2016
Hi All,
GUI HIDE ALL is not performing the way I would expect!
This test code works but is slow because of the 1 sec pause. If I hold down the button it generates an error :-
Option EXPLICIT
GUI DEFAULT HIDDEN
GUI INTERRUPT guiAction
CLS
Font 1,2
' Controls that are on the screen all the time or for more than 1 screen
Const pg0Prev = 1
Const pg0Next = 2
GUI BUTTON pg0Prev, "< Prev.",10,200,130,35,RGB(BLack),RGB(Green)
GUI BUTTON pg0Next, "Next >",180,200,130,35,RGB(Black),RGB(Green)
GUI INTERRUPT guiAction ' Turn the touch interrupt on
DrawPage
' +++++++++++++++++++++++++++++ START MAIN +++++++++++++++++++++++++++++++
' ++++++++++++++++++++++++++++++ SUBS BELOW ++++++++++++++++++++++++++++++
Sub guiAction
Local I,J As integer
Local TR As integer = Touch(REF)
GUI INTERRUPT 0 ' make sure we don't call again until finished processing
DrawPage
GUI INTERRUPT guiAction ' turn the touch interrupt back on
End Sub
Sub DrawPage
Local n As integer
Pause 1000
GUI HIDE ALL
' Other pages were loaded in here but removed for this test
For n = 1 To 2
GUI SHOW n
Next
End Sub
My thoughts are that the command should do as it says and hide all controls regardless of whether a control is pressed or not.
Is there a suitable workaround I have not thought of?
Rob White
Posted: 01:02pm 24 Feb 2016
Changing the state of a control while the control is being activated (touched) will generally cause a problem. This is something that I will have to look at but the solution will probably be to throw an error message if that happens.
It would be best to hide the control on the touch up interrupt as the control is not then being touched.
disco4now
Posted: 01:15pm 24 Feb 2016
Geoff was too quick, but as I have dug this up I will add it anyway.
A similar issue is discussed in this thread. I have quoted the last entry which shows @grogster's method of not doing Deletes while actually in the control's touch code, which can manifest as many strange issues. (Later advice from Geoff and in the manual I think now suggests you should try to code so you don't need CLS when you have GUI controls i.e only use the GUI controls)
Gerry
Similiar Issue
  Grogster said   UPDATE:
I have introduced a new routine to clear the GUI which seems to be working. It is a variation of disco4now's code, but instead of tracking each control, it just waits till it detects no control being touched, and THEN it deletes the controls. This is called at the start of each NEW screen of controls via the CLEARSCR sub:
SUB CLEARSCR
Timer=0
Do:Loop Until Touch(UP)=1 'Wait until no touch control being touched.
X=Timer
If DEBUG then Print "Delete GUI in " + STR$(X) + " ms."
GUI delete all
CLS
End SUB
This seems to be working fine for the moment(no corruption), and saves me having to to keep track of individual controls.
Geoff has advised me via email, that deleting GUI controls while they are still active is a big no-no, and this was what was happening when I look at the debug delays in the new routine - it takes a few tens of ms before the touch is released(depending on how fast you are tapping buttons etc), and deleting controls as part of the new screen, when the old button is still "Down" - not a good thing.
disco4now already hinted as much in his posting on this thread, and it would seem he was indeed quite right.
Oh well - I am learning new stuff, as GUI controls are totally new territory for me!
F4 H7FotSF4xGT
Posted: 01:28pm 24 Feb 2016
Yes, further to this, it is vitally important not to change a control while it is still active. Geoff also mentioned to me that if you have to use CLS at all to clear the screen in a GUI, then you are doing it wrong.
This was great advice, and a nice simple rule for me to remember.
I was having similar issues with my textbox or numberbox(I forget which one), in that once I entered in the correct text, the code looped to a new screen and issued the CLS command. This cleared the screen, yes, but the box was still technically active and generated some very strange behaviour.
Using GUI DEFAULT HIDDEN and GUI HIDE ALL at the top of the code would be how I now start GUI work, and only GUI SHOW the ones you want on any one screen.
I also have to get used to using GUI CAPTION instead of TEXT, as that was also causing me screen problems.
Bizzie
Posted: 01:36pm 24 Feb 2016
Thanks all,
Changing to the touch up interrupt works fine!
Rob White
