Local Time 17:39 23 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : graphical lcd detect
drkl
Posted: 07:57pm 08 Mar 2016
Hello,
How can i detect, that a graphical LCD panel phisically connected or not?
(MM Ver 5.1)
drkl
Posted: 09:56pm 08 Mar 2016
Which type of display?
ILI9341 - you can't easily
SSD1963, you could write a Cfunction to read the controller ID
other displays will have other solutions or not
UPDATE
Just had an idea, use an analogue pin to measure the voltage on the display side of the Backlight dropper resistor. When the display isn't connected you will see 3.3V (or 5V via a voltage divider) and something lower when it is - simples Edited by matherp 2016-03-10
