Local Time 15:20 23 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Great value 4.3" SSD1963 TFT displays
Posted: 02:05am 16 Mar 2016
This is the best deal I've seen on these displays.
The 4.3" display has a number of advantages over the bigger ones.
It is brighter and because it is lower resolution it is faster to drive. However, the biggest advantage is that the the graphics memory is big enough to hold 3 full pages of information. This means that using the paged driver capability you can write to a a range of lines that can't be seen and then only switch to those lines once the write is complete. This can completely eliminate any flicker. The driver also supports transparent text so that the background is preserved. To use this the RD line must be connected. Then text can be displayed transparently using the code "1" as the background colour.
One thing missing in the demo I posted was a 10msec wait after switching the page. This is essential to allow the complete screen to refresh with the new page otherwise immediate writes to the previous page may produce flicker artifacts as the screen refreshes
e.g.
SSD1963 2 'switch to page 2: lines 272 to 543
pause 10
bigfix
Posted: 04:37am 16 Mar 2016
Does not ship to Austria or Germany - only more expensive offers...
Anyhow, I bought some other displays from Eckstein in Germany via Ebay
They usually have good docs about their displays to download
So this display looks similar:
Eckstein SSD1963
Here is the docu pointer:
http://ecksteinimg.de/Datasheet/CP11007.zip
davematt
Posted: 06:42pm 06 Apr 2016
Just received 2 of these boards. Connecting just the backlight and ground pins I can get no response. Strangely, a very similar board has the same problem. I can believe 1 or 2 faulty boards, but 3?
Wondering if anyone can help, or can confirm that I should "see the light"?
TIA, Dave.
paceman
Posted: 07:05pm 06 Apr 2016
Dave, page 15 of Geoff's 'Micromite Plus Manual' states the following about setting up SSD9163 touch panels. This might help.
Greg
Most SSD1963 based LCD panels have three pairs of solder pads on the PCB which are grouped under the
heading "Backlight Control". Normally the pair marked "LED-A" are shorted together with a zero ohm resistor
and this allows control of the backlight's brightness with a PWM (pulse width modulated) signal on the LED-A
pin of the display panel's main connector. The Micromite Plus fully supports this form of control and if you do
not want to be bothered with the details you can specify the I/O pin used to drive the LED-A pin in the OPTION
LCDPANEL command (below).
However, it is better to use the SSD1963 controller to generate this signal as it frees up one I/O pin and it allows
the brightness to be controlled with a finer degree of resolution (1% instead of 5% steps). To use the SSD1963 for
brightness control the zero ohm resistor should be removed from the pair marked "LED-A" and used to short the
nearby pair of solder pads marked "1963-PWM". The Micromite Plus can then control the brightness by sending
commands to the SSD1963 controller.
In either case the BACKLIGHT command will work the same and can be used to dynamically change the
display's brightness.
Generally 7 inch and larger displays have a separate pin on the connector (marked 5V) for powering the backlight
from a 5V supply. If this pin is not provided the backlight power will be drawn from the 3.3V pin. Note that the
power drawn by the backlight can be considerable. For example, a 7 inch display will typically draw 330mA
from the 5V pin.
davematt
Posted: 10:03pm 06 Apr 2016
Many thanks Greg. You (and Geoff) have 'lightened my darkness'. D
Posted: 10:15pm 06 Apr 2016
  Quote  Connecting just the backlight and ground pins I can get no response.
This won't work. The LED_A pin is the input to a digital switch which switches the 3.3V input to the backlight booster circuit so to get anything you need to wire 3.3V, GND and LED. The modules ship with the backlight control on "LED_A". If you move it to 1963_PWM then Geoff's BACKLIGHT control can be usedEdited by matherp 2016-04-08
