Local Time 16:52 23 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : can bus
centrex
Posted: 09:45pm 17 Mar 2016
A little off topic but has anyone fitted load resistors to the can bus for led trailer lights.
If so what value resistors where used, the 50watt 6 ohm resistors seen on the web seem a bit over the top.
Thanks.
Cliff
Dylan
Posted: 12:58am 18 Mar 2016
https://www.hidplanet.com/forums/forum/general-discussion/leds/27021-i-need-a-cheap-alternative-to-6-ohm-50w-load-resist ors ?
plover
Posted: 01:41pm 18 Mar 2016
Link does not work for me?
Tried above as well but so far no luck.
centrex
Posted: 02:54pm 18 Mar 2016
This works, but what sort of load does the can bus system really require to make it work.
Pulling 30 plus watts for taillights and flashers appears to defeat the purpose of the led lights other than their reliability.
Heating a resistor just to trigger a system appears to be a bit odd.
Delete the gap in resist ors ? then it works.
Edited by centrex 2016-03-20
Cliff
