Local Time 16:07 23 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Using SETPIN with multiple pins
Herry
Posted: 07:49pm 24 Mar 2016
I'm sure there must be a reference that answers this question, but I'm blowed if I can find it. I want to program
SETPIN 2, DIN, PULLUP
SETPIN 5, DIN, PULLUP
SETPIN 16, DIN, PULLUP
...ETC.
I then signal branches of my program according to which pin is linked to earth, thus: IF PIN(2) = LOW THEN... (do something
ELSE... (or use CASE).
In my program I actually have several choices (a multiway switch). I am wondering if I can say something like
SETPIN 2,5,16... DIN, PULLUP
Senior?!  Whatever it says, I'm a complete and utter beginner...
jman
Posted: 10:15pm 24 Mar 2016
Hi
No you cannot set more than pin at a time.
You can read more than one pin at time with
PORT(start, nbr [,start, nbr]…)
(Manual page 76)
You can write to more than one pin at a time with
PORT(start, nbr [,start, nbr]…) = value
(Manual page 65)
Jman
Herry
Posted: 10:22pm 24 Mar 2016
Thanks. And I remember the TRS80 so well, and David Lien's book too!
Bizzie
Posted: 01:20am 25 Mar 2016
Which mite are you using?
I would use interrupts assuming there are enough available, no problem if using a plus as all I/O lines can be setup with interrupts.
See SETPIN pin, cfg, target [,option]
Then you only need a sub(Target) for each pin.
Rob White
