Local Time 14:45 23 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Memory reservation
drkl
Posted: 10:34am 08 Apr 2016
Hello,
Here is a code:
option explicit
option default NONE
'DIM A(1000) AS INTEGER 'MEMORY RESERVATION 1000*8 BYTE -OK
'DIM A(1000) AS FLOAT 'MEMORY RESERVATION 1000*4 BYTE - OK
'DIM A(100) AS STRING 'MEMORY RESERVATION 100*256 BYTE - OK
DIM A(100) AS STRING LENGTH 10 'MEMORY RESERVATION 100*256 BYTE - WHY???
After run:
>RUN
> MEMORY
Flash:
1K ( 1%) Program (3 lines)
59K (99%) Free
RAM:
25K (47%) 1 Variable
0K ( 0%) General
28K (53%) Free
There are somebody who can explain it?
drkl
drkl
Posted: 10:58am 08 Apr 2016
Sorry, I found the solution
Must use an other definition:
DIM string a(1000) LENGTH 10 'MEMORY RESERVATION 1000*11 BYTE - OK
drkl
