Local Time 14:45 23 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Temperature differential logic
Phil23
Posted: 01:10pm 09 Apr 2016
Just not quite getting my rusty brain around temperature differential logic.
This simple code works, but doesn't allow for any differential. Like say 0.3°
If TmpCur<TmpTar Then 'Compare Current & Target temperature.
PumpStat="Running" 'Turn the Pump on.
pin(PinLed1)=1
else
PumpStat="Standby" 'Turn the Pump off.
pin(PinLed1)=0
endif
Main reason I want differential, is not for Solar control, but for when I'm using the Heat Pump. I want to reduce the amount of times it cycles on & off.
Cheers.
atmega8
Posted: 02:05pm 09 Apr 2016
HYSTERESIS ?
Phil23
Posted: 02:08pm 09 Apr 2016
That's the term I should have used.
Ie,
When temperature gets to 34°C, stop heating, but don't start again before it falls below say 33.6°.
Guessing it will need some sort of cycle flag.
atmega8
Posted: 02:38pm 09 Apr 2016
This Is very simple.
HYSTERESIS is done by a Schmitt-Trigger.
You need a software Schmitt-Trigger like this:
if( Input > top)
LED = 1
else if( Input < min)
LED = 0Edited by atmega8 2016-04-11
Posted: 05:22pm 09 Apr 2016
try the following:
hyst = 1
If TmpCur<(TmpTar-hyst) Then 'Compare Current & Target temperature.
pin(PinLed1)=1
endif
If TmpCur>(TmpTar+hyst) Then 'Compare Current & Target temperature.
pin(PinLed1)=0
endif
when the current temperature falls 1 degree below the target temperature, the pump is turned on.
when the current temperature rises 1 degree above the target temperature, the pump turns off.
rob :-)
Phil23
Posted: 08:39pm 09 Apr 2016
  robert.rozee said   try the following:
hyst = 1
pin(PinLed1)=1
endif
pin(PinLed1)=0
endif
rob :-)
Thanks Rob,
That's basically what I came up with once I rested my brain & could thing logically again.
If TmpCur<(TmpTar - TmpDif) Then
pin(PinLed1)=1
else if TmpCur>(TmpTar) then
pin(PinLed1)=0
endif
Just not swinging on the high side of the set temp.
Will just have to add a minimum wait timer on it for when it's in heat pump mode now so the compressor unit can depressurise.
Have found a good example some else has done of Ardurino over here.
Phil.
