Local Time 14:45 23 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MM2 8*13 Font as FONT1.BAS
disco4now
Posted: 06:49pm 11 Apr 2016
Is there a .BAS font file with the MM2 inbuilt 8*13 pixel Font 1 anywhere. I would like to use it as the starting point in FontTweak and adjust a few characters foe use in a specific program.
Gerry
F4 H7FotSF4xGT
Posted: 09:07pm 11 Apr 2016
Here is the C source which should work with Jim's editor
const unsigned char X_8x13_LE[] = {
0x08, 0x0D, 0x20, 0x5F,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, // space
0x00, 0x00, 0x10, 0x10, 0x10, 0x10, 0x10, 0x10, 0x10, 0x00, 0x10, 0x00, 0x00, // !
0x00, 0x00, 0x24, 0x24, 0x24, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, // "
0x00, 0x00, 0x00, 0x24, 0x24, 0x7E, 0x24, 0x7E, 0x24, 0x24, 0x00, 0x00, 0x00, // #
0x00, 0x00, 0x00, 0x10, 0x3C, 0x50, 0x38, 0x14, 0x78, 0x10, 0x00, 0x00, 0x00, // $
0x00, 0x00, 0x22, 0x52, 0x24, 0x08, 0x08, 0x10, 0x24, 0x2A, 0x44, 0x00, 0x00, // %
0x00, 0x00, 0x00, 0x00, 0x30, 0x48, 0x48, 0x30, 0x4A, 0x44, 0x3A, 0x00, 0x00, // &
0x00, 0x00, 0x38, 0x30, 0x40, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, // '
0x00, 0x00, 0x04, 0x08, 0x08, 0x10, 0x10, 0x10, 0x08, 0x08, 0x04, 0x00, 0x00, // (
0x00, 0x00, 0x20, 0x10, 0x10, 0x08, 0x08, 0x08, 0x10, 0x10, 0x20, 0x00, 0x00, // )
0x00, 0x00, 0x00, 0x00, 0x24, 0x18, 0x7E, 0x18, 0x24, 0x00, 0x00, 0x00, 0x00, // *
0x00, 0x00, 0x00, 0x00, 0x10, 0x10, 0x7C, 0x10, 0x10, 0x00, 0x00, 0x00, 0x00, // +
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x38, 0x30, 0x40, 0x00, // ,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x7E, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, // -
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x10, 0x38, 0x10, 0x00, // .
0x00, 0x00, 0x02, 0x02, 0x04, 0x08, 0x10, 0x20, 0x40, 0x80, 0x80, 0x00, 0x00, // /
0x00, 0x00, 0x18, 0x24, 0x42, 0x42, 0x42, 0x42, 0x42, 0x24, 0x18, 0x00, 0x00, // 0
0x00, 0x00, 0x10, 0x30, 0x50, 0x10, 0x10, 0x10, 0x10, 0x10, 0x7C, 0x00, 0x00, // 1
0x00, 0x00, 0x3C, 0x42, 0x42, 0x02, 0x04, 0x18, 0x20, 0x40, 0x7E, 0x00, 0x00, // 2
0x00, 0x00, 0x7E, 0x02, 0x04, 0x08, 0x1C, 0x02, 0x02, 0x42, 0x3C, 0x00, 0x00, // 3
0x00, 0x00, 0x04, 0x0C, 0x14, 0x24, 0x44, 0x44, 0x7E, 0x04, 0x04, 0x00, 0x00, // 4
0x00, 0x00, 0x7E, 0x40, 0x40, 0x5C, 0x62, 0x02, 0x02, 0x42, 0x3C, 0x00, 0x00, // 5
0x00, 0x00, 0x1C, 0x20, 0x40, 0x40, 0x5C, 0x62, 0x42, 0x42, 0x3C, 0x00, 0x00, // 6
0x00, 0x00, 0x7E, 0x02, 0x04, 0x08, 0x08, 0x10, 0x10, 0x20, 0x20, 0x00, 0x00, // 7
0x00, 0x00, 0x3C, 0x42, 0x42, 0x42, 0x3C, 0x42, 0x42, 0x42, 0x3C, 0x00, 0x00, // 8
0x00, 0x00, 0x3C, 0x42, 0x42, 0x46, 0x3A, 0x02, 0x02, 0x04, 0x38, 0x00, 0x00, // 9
0x00, 0x00, 0x00, 0x00, 0x10, 0x38, 0x10, 0x00, 0x00, 0x10, 0x38, 0x10, 0x00, // :
0x00, 0x00, 0x00, 0x00, 0x10, 0x38, 0x10, 0x00, 0x00, 0x38, 0x30, 0x40, 0x00, // ;
0x00, 0x00, 0x02, 0x04, 0x08, 0x10, 0x20, 0x10, 0x08, 0x04, 0x02, 0x00, 0x00, // <
0x00, 0x00, 0x00, 0x00, 0x00, 0x7E, 0x00, 0x00, 0x7E, 0x00, 0x00, 0x00, 0x00, // =
0x00, 0x00, 0x40, 0x20, 0x10, 0x08, 0x04, 0x08, 0x10, 0x20, 0x40, 0x00, 0x00, // >
0x00, 0x00, 0x3C, 0x42, 0x42, 0x02, 0x04, 0x08, 0x08, 0x00, 0x08, 0x00, 0x00, // ?
0x00, 0x00, 0x3C, 0x42, 0x42, 0x4E, 0x52, 0x56, 0x4A, 0x40, 0x3C, 0x00, 0x00, // @
0x00, 0x00, 0x18, 0x24, 0x42, 0x42, 0x42, 0x7E, 0x42, 0x42, 0x42, 0x00, 0x00, // A
0x00, 0x00, 0xFC, 0x42, 0x42, 0x42, 0x7C, 0x42, 0x42, 0x42, 0xFC, 0x00, 0x00, // B
0x00, 0x00, 0x3C, 0x42, 0x40, 0x40, 0x40, 0x40, 0x40, 0x42, 0x3C, 0x00, 0x00, // C
0x00, 0x00, 0xFC, 0x42, 0x42, 0x42, 0x42, 0x42, 0x42, 0x42, 0xFC, 0x00, 0x00, // D
0x00, 0x00, 0x7E, 0x40, 0x40, 0x40, 0x78, 0x40, 0x40, 0x40, 0x7E, 0x00, 0x00, // E
0x00, 0x00, 0x7E, 0x40, 0x40, 0x40, 0x78, 0x40, 0x40, 0x40, 0x40, 0x00, 0x00, // F
0x00, 0x00, 0x3C, 0x42, 0x40, 0x40, 0x40, 0x4E, 0x42, 0x46, 0x3A, 0x00, 0x00, // G
0x00, 0x00, 0x42, 0x42, 0x42, 0x42, 0x7E, 0x42, 0x42, 0x42, 0x42, 0x00, 0x00, // H
0x00, 0x00, 0x7C, 0x10, 0x10, 0x10, 0x10, 0x10, 0x10, 0x10, 0x7C, 0x00, 0x00, // I
0x00, 0x00, 0x1E, 0x04, 0x04, 0x04, 0x04, 0x04, 0x04, 0x44, 0x38, 0x00, 0x00, // J
0x00, 0x00, 0x42, 0x44, 0x48, 0x50, 0x60, 0x50, 0x48, 0x44, 0x42, 0x00, 0x00, // K
0x00, 0x00, 0x40, 0x40, 0x40, 0x40, 0x40, 0x40, 0x40, 0x40, 0x7E, 0x00, 0x00, // L
0x00, 0x00, 0x82, 0x82, 0xC6, 0xAA, 0x92, 0x92, 0x82, 0x82, 0x82, 0x00, 0x00, // M
0x00, 0x00, 0x42, 0x42, 0x62, 0x52, 0x4A, 0x46, 0x42, 0x42, 0x42, 0x00, 0x00, // N
0x00, 0x00, 0x3C, 0x42, 0x42, 0x42, 0x42, 0x42, 0x42, 0x42, 0x3C, 0x00, 0x00, // O
0x00, 0x00, 0x7C, 0x42, 0x42, 0x42, 0x7C, 0x40, 0x40, 0x40, 0x40, 0x00, 0x00, // P
0x00, 0x00, 0x3C, 0x42, 0x42, 0x42, 0x42, 0x42, 0x52, 0x4A, 0x3C, 0x02, 0x00, // Q
0x00, 0x00, 0x7C, 0x42, 0x42, 0x42, 0x7C, 0x50, 0x48, 0x44, 0x42, 0x00, 0x00, // R
0x00, 0x00, 0x3C, 0x42, 0x40, 0x40, 0x3C, 0x02, 0x02, 0x42, 0x3C, 0x00, 0x00, // S
0x00, 0x00, 0xFE, 0x10, 0x10, 0x10, 0x10, 0x10, 0x10, 0x10, 0x10, 0x00, 0x00, // T
0x00, 0x00, 0x42, 0x42, 0x42, 0x42, 0x42, 0x42, 0x42, 0x42, 0x3C, 0x00, 0x00, // U
0x00, 0x00, 0x82, 0x82, 0x44, 0x44, 0x44, 0x28, 0x28, 0x28, 0x10, 0x00, 0x00, // V
0x00, 0x00, 0x82, 0x82, 0x82, 0x82, 0x92, 0x92, 0x92, 0xAA, 0x44, 0x00, 0x00, // W
0x00, 0x00, 0x82, 0x82, 0x44, 0x28, 0x10, 0x28, 0x44, 0x82, 0x82, 0x00, 0x00, // X
0x00, 0x00, 0x82, 0x82, 0x44, 0x28, 0x10, 0x10, 0x10, 0x10, 0x10, 0x00, 0x00, // Y
0x00, 0x00, 0x7E, 0x02, 0x04, 0x08, 0x10, 0x20, 0x40, 0x40, 0x7E, 0x00, 0x00, // Z
0x00, 0x00, 0x3C, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x3C, 0x00, 0x00, // [
0x00, 0x00, 0x80, 0x80, 0x40, 0x20, 0x10, 0x08, 0x04, 0x02, 0x02, 0x00, 0x00, // backslash
0x00, 0x00, 0x78, 0x08, 0x08, 0x08, 0x08, 0x08, 0x08, 0x08, 0x78, 0x00, 0x00, // ]
0x00, 0x00, 0x10, 0x28, 0x44, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, // ^
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xFE, 0x00, // _
0x00, 0x00, 0x38, 0x18, 0x04, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, // `
0x00, 0x00, 0x00, 0x00, 0x00, 0x3C, 0x02, 0x3E, 0x42, 0x46, 0x3A, 0x00, 0x00, // a
0x00, 0x00, 0x40, 0x40, 0x40, 0x5C, 0x62, 0x42, 0x42, 0x62, 0x5C, 0x00, 0x00, // b
0x00, 0x00, 0x00, 0x00, 0x00, 0x3C, 0x42, 0x40, 0x40, 0x42, 0x3C, 0x00, 0x00, // c
0x00, 0x00, 0x02, 0x02, 0x02, 0x3A, 0x46, 0x42, 0x42, 0x46, 0x3A, 0x00, 0x00, // d
0x00, 0x00, 0x00, 0x00, 0x00, 0x3C, 0x42, 0x7E, 0x40, 0x42, 0x3C, 0x00, 0x00, // e
0x00, 0x00, 0x1C, 0x22, 0x20, 0x20, 0x7C, 0x20, 0x20, 0x20, 0x20, 0x00, 0x00, // f
0x00, 0x00, 0x00, 0x00, 0x00, 0x3A, 0x44, 0x44, 0x38, 0x40, 0x3C, 0x42, 0x3C, // g
0x00, 0x00, 0x40, 0x40, 0x40, 0x5C, 0x62, 0x42, 0x42, 0x42, 0x42, 0x00, 0x00, // h
0x00, 0x00, 0x00, 0x10, 0x00, 0x30, 0x10, 0x10, 0x10, 0x10, 0x7C, 0x00, 0x00, // i
0x00, 0x00, 0x00, 0x04, 0x00, 0x0C, 0x04, 0x04, 0x04, 0x04, 0x44, 0x44, 0x38, // j
0x00, 0x00, 0x40, 0x40, 0x40, 0x44, 0x48, 0x70, 0x48, 0x44, 0x42, 0x00, 0x00, // k
0x00, 0x00, 0x30, 0x10, 0x10, 0x10, 0x10, 0x10, 0x10, 0x10, 0x7C, 0x00, 0x00, // l
0x00, 0x00, 0x00, 0x00, 0x00, 0xEC, 0x92, 0x92, 0x92, 0x92, 0x82, 0x00, 0x00, // m
0x00, 0x00, 0x00, 0x00, 0x00, 0x5C, 0x62, 0x42, 0x42, 0x42, 0x42, 0x00, 0x00, // n
0x00, 0x00, 0x00, 0x00, 0x00, 0x3C, 0x42, 0x42, 0x42, 0x42, 0x3C, 0x00, 0x00, // o
0x00, 0x00, 0x00, 0x00, 0x00, 0x5C, 0x62, 0x42, 0x62, 0x5C, 0x40, 0x40, 0x40, // p
0x00, 0x00, 0x00, 0x00, 0x00, 0x3A, 0x46, 0x42, 0x46, 0x3A, 0x02, 0x02, 0x02, // q
0x00, 0x00, 0x00, 0x00, 0x00, 0x5C, 0x22, 0x20, 0x20, 0x20, 0x20, 0x00, 0x00, // r
0x00, 0x00, 0x00, 0x00, 0x00, 0x3C, 0x42, 0x30, 0x0C, 0x42, 0x3C, 0x00, 0x00, // s
0x00, 0x00, 0x00, 0x20, 0x20, 0x7C, 0x20, 0x20, 0x20, 0x22, 0x1C, 0x00, 0x00, // t
0x00, 0x00, 0x00, 0x00, 0x00, 0x44, 0x44, 0x44, 0x44, 0x44, 0x3A, 0x00, 0x00, // u
0x00, 0x00, 0x00, 0x00, 0x00, 0x44, 0x44, 0x44, 0x28, 0x28, 0x10, 0x00, 0x00, // v
0x00, 0x00, 0x00, 0x00, 0x00, 0x82, 0x82, 0x92, 0x92, 0xAA, 0x44, 0x00, 0x00, // w
0x00, 0x00, 0x00, 0x00, 0x00, 0x42, 0x24, 0x18, 0x18, 0x24, 0x42, 0x00, 0x00, // x
0x00, 0x00, 0x00, 0x00, 0x00, 0x42, 0x42, 0x42, 0x46, 0x3A, 0x02, 0x42, 0x3C, // y
0x00, 0x00, 0x00, 0x00, 0x00, 0x7E, 0x04, 0x08, 0x10, 0x20, 0x7E, 0x00, 0x00, // z
0x00, 0x00, 0x0E, 0x10, 0x10, 0x08, 0x30, 0x08, 0x10, 0x10, 0x0E, 0x00, 0x00, // {
0x00, 0x00, 0x10, 0x10, 0x10, 0x10, 0x10, 0x10, 0x10, 0x10, 0x10, 0x00, 0x00, // |
0x00, 0x00, 0x70, 0x08, 0x08, 0x10, 0x0C, 0x10, 0x08, 0x08, 0x70, 0x00, 0x00, // }
0x00, 0x00, 0x24, 0x54, 0x48, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, // ~
disco4now
Posted: 10:02pm 11 Apr 2016
Thanks,
I had to replace this first header line
with one taken from another font
fontdatatype Misc_12x20_LE[2854] PROGMEM={
before it would load into FontTweak.
But all good after that.
GerryEdited by disco4now 2016-04-13
F4 H7FotSF4xGT
disco4now
Posted: 02:07am 12 Apr 2016
The font saved as a BAS file.
' Font1_8x13.bas
' Font type : Full (95 characters)
' Font size : 8x13 pixels
' Memory usage : 1239 bytes
' Font adapted from: http://www.rinkydinkelectronics.com/r_fonts.php
DefineFont #8
5F200D08 00000000 00000000 00000000 10000000 10101010 10001010 00000000
00242424 00000000 00000000 24240000 247E247E 00000024 10000000 1438503C
00001078 22000000 08082452 442A2410 00000000 48300000 444A3048 0000003A
40303800 00000000 00000000 08040000 10101008 00040808 20000000 08081010
20101008 00000000 18240000 0024187E 00000000 10000000 10107C10 00000000
00000000 00000000 40303800 00000000 7E000000 00000000 00000000 00000000
10000000 00001038 04020200 40201008 00008080 24180000 42424242 00182442
10000000 10105030 7C101010 00000000 0242423C 40201804 0000007E 04027E00
02021C08 00003C42 0C040000 44442414 0004047E 7E000000 625C4040 3C420202
00000000 4040201C 4242625C 0000003C 04027E00 10100808 00002020 423C0000
423C4242 003C4242 3C000000 3A464242 38040202 00000000 38100000 10000010
00001038 10000000 00001038 00403038 04020000 10201008 00020408 00000000
007E0000 00007E00 00000000 08102040 20100804 00000040 42423C00 08080402
00000800 423C0000 56524E42 003C404A 18000000 42424224 4242427E 00000000
424242FC 4242427C 000000FC 40423C00 40404040 00003C42 42FC0000 42424242
00FC4242 7E000000 78404040 7E404040 00000000 4040407E 40404078 00000040
40423C00 424E4040 00003A46 42420000 427E4242 00424242 7C000000 10101010
7C101010 00000000 0404041E 44040404 00000038 48444200 48506050 00004244
40400000 40404040 007E4040 82000000 92AAC682 82828292 00000000 52624242
4242464A 00000042 42423C00 42424242 00003C42 427C0000 407C4242 00404040
3C000000 42424242 3C4A5242 00000002 4242427C 4448507C 00000042 40423C00
02023C40 00003C42 10FE0000 10101010 00101010 42000000 42424242 3C424242
00000000 44448282 28282844 00000010 82828200 92929282 000044AA 82820000
28102844 00828244 82000000 10284482 10101010 00000000 0804027E 40402010
0000007E 20203C00 20202020 00003C20 80800000 08102040 00020204 78000000
08080808 78080808 00000000 00442810 00000000 00000000 00000000 00000000
00FE0000 18380000 00000004 00000000 00000000 023C0000 3A46423E 00000000
5C404040 62424262 0000005C 00000000 4040423C 00003C42 02020000 42463A02
003A4642 00000000 423C0000 3C42407E 00000000 2020221C 2020207C 00000020
00000000 3844443A 3C423C40 40400000 42625C40 00424242 00000000 10300010
7C101010 00000000 0C000400 04040404 00384444 40404000 48704844 00004244
10300000 10101010 007C1010 00000000 92EC0000 82929292 00000000 5C000000
42424262 00000042 00000000 4242423C 00003C42 00000000 42625C00 40405C62
00000040 463A0000 023A4642 00000202 5C000000 20202022 00000020 00000000
0C30423C 00003C42 20000000 20207C20 001C2220 00000000 44440000 3A444444
00000000 44000000 28284444 00000010 00000000 92928282 000044AA 00000000
18244200 00422418 00000000 42420000 023A4642 00003C42 7E000000 20100804
0000007E 10100E00 10083008 00000E10 10100000 10101010 00101010 70000000
0C100808 70080810 00000000 00485424 00000000 000000
End DefineFont
F4 H7FotSF4xGT
