Local Time 12:27 23 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : SSD1963 Display
palcal
Posted: 12:50pm 30 Apr 2016
I am using a 100 pin chip (SnadPic} with a backboard I designed. The board has provision for both an ILI9341 and SSD1963 display. It works fine with the ILI9341 but when configure the board for the SSD1963 and plug in the display it won't work. If I try to connect to the console I get a message "USB device not recognised". If I unplug the display I can connect to the console OK. I have checked all connections OK.
Any ideas?
Paul.
Edit... I also checked to voltage with the display in and it is OK.Edited by palcal 2016-05-01
Posted: 03:24pm 30 Apr 2016
I wouldn't mind betting that you are using the USB for power and the display is loading it down too much. A SSD1963 panel can draw up to 0.75A.
I would be helpful if you could provide more info. What power supply? Have you used the correct OPTION command? Does the USB fail before or after the OPTION command? Does the display's backlight come on? Have you specified the LED_A pin in the OPTION command or have you modded your display to use the SSD1963 PWM for backlight control?
palcal
Posted: 06:06pm 30 Apr 2016
Thanks Geoff, I checked the supply voltage and it was 3.27V so I thought that was OK. I have since connected to an external supply and all is OK.
Thanks.
Paul.
