Forum Index : Microcontroller and PC projects : Development Environment
Hi all, Finally at the stage where I can connect my controller to the Spa & use some real inputs & control a few relays. What I'd like to do is put just a basic breadboard outside, with No LCD Touch, and keep the Backpack inside with dummy sensors & a few leds for development purposes. Is the something I can do in code so the one in service ignores the missing LCD screen at this time. Would rather not have two sets of code, or have to be commenting things out each time I update the one that's in use. Thanks Phil |
You could configure them the same but just not plug the LCD panel in on the outside one. MMBasic will still try to send data to the display but it will not throw an error. Geoff Geoff Graham - http://geoffg.net |
Thanks, That's what I really needed to know, the fact that It would not create errors. |
