Local Time 11:41 23 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PORT command in frimware 5.1+...
Posted: 09:02pm 12 May 2016
Page 65 of the standard 5.1 manual mentions under the PORT command that you can specify additional groups of pins to make up the port. This was always supported, but can you now specify more then TWO groups of pins?
Example: PORT (47,4,52,2,58,1) = %B1111111
The example assumes a 100-pin MM+ device.
Yes?
No?
MicroBlocks
Posted: 10:03pm 12 May 2016
I used
PORT(15,3,21,4,26,1)
before so it should be possible.
Posted: 10:32pm 12 May 2016
Cool, thanks.
I don't have a 100-pin device handy to test this on, but I will hook up some LED's and a 64-pin chip and run a couple of tests to be sure.
I seem to recall that earlier versions of MMBASIC did not allow more then two groups of numbers when setting the port.
Posted: 10:43pm 12 May 2016
  Quote  I seem to recall that earlier versions of MMBASIC did not allow more then two groups of numbers when setting the port.
Possibly the case but I've certainly used
PORT(3,1,2,1,38,1,37,1,36,1,27,1,26,1,25,1) in V5.0
Posted: 10:46pm 12 May 2016
WOW!
I need not worry then.
