Forum Index : Microcontroller and PC projects : RTC problem with a CGColorMax1
| f1fco Senior Member Joined: 18/03/2012 Location: FrancePosts: 155 |
I own a CGColorMax1 with firmware 4.5 (mm.ver -> 4.05) but I cannot have the RTC if I update date and time (DATE$="13/05/16" and TIME$="17:00:00", I lost date and time when I shutdown power supply I not have the message under the Maximite logo saying that the clock is not set why ??? is it a special version of firmware for the CGColorMax1 ? please, help me Pierre, from Nimes, south of France 73s de F1FCO |
curious, on my board the +5v is only 3.98 V ! with a scope, I have not the 32768 Hz oscillations on pins 1 and 2 of the DS1307 and of course no signals on SDA/SCL outputs Pierre. 73s de F1FCO |
Do you have a backup battery installed? The RTC will not work without it, even when powered normally. Geoff Geoff Graham - http://geoffg.net |
the BR1225 battery is on the board 3.27V and also 3.27V on the pin 3 of DS1307 73s de F1FCO |
