Local Time 09:39 23 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Question about LCD drivers
kiiid
Posted: 02:59am 10 Jun 2016
I wonder would it be feasible if the drivers supplied as built-in with the MM+, are upgraded to support the RD pin as well? This could be done if additional optional parameter specifying the RD pin is added to the OPTION LCDPANEL command. If it is missing - no RD pin will be assigned, otherwise the specified pin number will be used for the read signal. I think having support for reading from the LCD opens a whole new world for graphics and even memory expansion.
Thoughts?
ThanksEdited by kiiid 2016-06-11
http://rittle.org
Posted: 04:14am 10 Jun 2016
I presume that you are referring to the SSD1963 drivers and this is something I am planning for a future version. Peter Mather has done some great work in this area.
The main issue is working out how this feature will be used within MMBasic.
Zonker
Posted: 08:37am 12 Jun 2016
The R61505V also has an updated RD pin based driver that adds the "objects over objects" effect, so on the next PCB turn, will be adding the pin... I am having a hard time getting to understand how to properly implement all the functions of the driver code... Anyway, I too wanted to chime-in on the RD pin thing, cause I think having this will greatly help when creating more complicated GUI controls for the end user... Making it easy to implement system device controls...
Possibly taking this a step further, if we could somehow create an app to have the end user take a baseline selection of objects, a graphical editor (simulator?) to allow the end user to "dress" the control, (colors,shape,set-points,trigger types.. ect... ) and then save the construct for later use. Hit a button, and the text window would spit out a basic (pun intended) program frame work ready for integration into their program..! This is kind of how 4D systems does with there stuff...
Just more thoughts...
Thanks Gent's Edited by Zonker 2016-06-13
