Local Time 08:52 23 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : mario bros etc on pic32mx using emulator
isochronic
Posted: 12:59pm 16 Jun 2016
this popped up on google - uses an emulator running on a pic32mx
to run small classic video games
mario bros
MicroBlocks
Posted: 05:50pm 16 Jun 2016
Unfortunately a project from 2010!
And no further info available.
cosmic frog
Posted: 10:31pm 16 Jun 2016
Have a look at this guys work
click
micronut
Posted: 03:49am 17 Jun 2016
There is also the Chameleon PIC which uses the PIC24 for computing and a Propeller for VGA, NTSC/PAL, Audio and Keyboard input.
The PIC24 in the Chameleon can communicate with 4 SPI devices. The first one is the Propeller, the second is a 1 MBit EEPROM and the last 2 are user defined. The 170 is pin and volt compatible to the PIC24 used and is in a socket so the PIC24 can be replaced with the 170. MMBasic has the SPI mapped differently than the Chameleon so it would have to be remapped and compiled to work with it. Also the PIC24 is driven by a 5 MHz crystal in a PLL for 40 MHz. I'm not sure if the 170 timing can be configured to run a 5 MHz PLL.
I have the Chameleon PIC and it would be an interesting project but right now I'm too busy to do it Edited by micronut 2016-06-18
