Local Time 08:04 23 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : LCD Back Pack ICSP
Phil23
Posted: 01:41pm 29 Jun 2016
Just tried to re-flash one of my back packs & the PicKit3 said it failed to find the device.
Just wondering what the conditions are for using the ICSP.
It was power externally, RTC, ESP & a few pins in use.
I've flashed them before, don't remember exactly how,
probably removed from the breadboard, with just a 5V supply connected.
Presume it's what's on Pins 4 & 5 causing the issue?
What other conditions need to apply for the ICSP port to be usable?
Phil.
Further detail:-
[Code]
'Pins used - Inputs
Dim Integer PinDemo=21 'Held Low on Demo Board, High on Real One
Dim Integer PinTmp=22 '1-Wire DS18B20 Input Pin
Dim Integer SolarPanel=4 'Analog input ~ 1000mV
Dim Integer LM336Ref=5 'LM336 Input - 2500mV
SetPin SolarPanel,AIN
Setpin LM336Ref,AIN
'Pins used - Outputs
Dim Integer PinLed1=24 'Status Pin (Green LED) Blinks to show main loop is running
dim Integer PinPump1=26 'Pump Running (Red LED) & also to be Pump Relay output
setpin(PinLed1),dout
Setpin(PinPump1),Dout,OC
[/code]
Posted: 12:23pm 30 Jun 2016
"failed to find the device" or "Target Vdd not detected" means that the PICkit3 could not see the +3.3V on the ICSP connector.
"Cannot read device ID" means that the PICkit3 could see the 3.3V but could not communicate with the chip. There are many causes if this including missing Vcap capacitor, external loading on the programming pins, chip not properly seated in its socket, etc.
The BASIC program will not have any effect on programming the chip but external components (caps, resistors, etc) connected to the programming pins could cause a "Cannot read device ID" error.
Phil23
Posted: 02:11pm 30 Jun 2016
Thanks Geoff,
It would be the analogue voltages on Pins 4 & 5 that made it fail.
1000 & 2500mV.
Will unplug it & flash it later.
