Local Time 07:16 23 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Heat Pump Monitoring
Phil23
Posted: 01:09pm 09 Jul 2016
Hi All,
This one id probably for those with some Frigie background.
Connected another Micromite to the 5 thermistors in the heat pump I'm modifying this morning.
These are the values I'm reading.
[Code]
Beta SteinHart
Air Temperature = 6.8 7.1
Evaporator Temp = -1.0 -1.1
Compressor Temp = 60.2 58.0
HE Input Temp = 19.4 20.0
HE Output Temp = 23.4 24.0
Temperature Rise = 4.0 3.9
[/code]
Just wondering what sort of temperatures I should be watching out for with regards to the compressor & evaporator.
Evaporator is currently below zero, and it's showing signs of icing up.
Temperature rise is probably usable as an indication of presence of water flow.
Any feed back & suggestions would be appreciated.
Phil
