OK so I've built an Explore 64 and I'm having trouble with the USB connection so wondering if I can hook up my serial cable and copy progs that way? Looks like pins 47 and 48 but no luck communicating as yet.
Thanks in advance :)
matherp Guru Joined: 11/12/2012 Location: United KingdomPosts: 11893
Posted: 11:41pm 16 Jul 2016
Console RX is pin 6, console TX is pin 58, See Micromite plus addendum manual pages 6,7
Also discovered the solution to one of my problems. I couldn't get my 7 segment led to work until I discovered I was using PIN (15) = 0 instead of PIN(15) = 0.
Much head scratching for such a small error!
All good now though.
boss Senior Member Joined: 19/08/2011 Location: CanadaPosts: 268
