Local Time 03:43 23 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : 1-Wire Temperatures revisited.
Phil23
Posted: 12:02pm 25 Aug 2016
Hoping someone can provide some feedback on this.
I currently have 2 different MM's each reading 6 DS18B20's on the same bus.
It's all working fine, with only an occasional error ~ once a day.
The failed read returns -0.0625°, all bits set;
HTemp=&b11111111 & LTemp=&b11111111.
I can see this by unplugging a single sensor.
I'm using 2 routines, one to initialise the sensors, the second reads them.
[Code] '========================OneWire Temperature Functions=========================
'Sub Initialises all DS18B20 Sensors on the Bus
'The below will set the resolution
'Onewire Write PinTmp, 2, 5, &HCC, &H4E,&H00,&H00,&HXX
' 9 bit=0.5 :1f - 93.75ms
'10 bit=0.250 :3f - 187.5ms
'11 bit=0.125 :5f - 375.0ms
'12 bit=0.0625:7f - 750.0ms
Sub InitTemp
Onewire Write PinTmp, 2, 5, &HCC, &H4E,&H00,&H00,&H7F 'Set the Resolution of all Sensors
OneWire Write PinTmp, 1, 2, &HCC, &H44 'Start Conversion on all Sensors
End Sub
'Function Returns the Termerature for the Serial# passed.
Function ReadTemp(TsSerial As Integer) As Float
Ts1=(TsSerial >> 48) and &hFF : Ts2=(TsSerial >> 40) and &hFF : Ts3=(TsSerial >> 32) and &hFF
Ts4=(TsSerial >> 24) and &hFF : Ts5=(TsSerial >> 16) and &hFF : Ts6=(TsSerial >> 8) and &hFF : Ts7=(TsSerial) and &hFF
'OneWire Write PinTmp, 1, 10, &H55,&H28,Ts1,Ts2,Ts3,Ts4,Ts5,Ts6,Ts7,&H44
'Check sensor is ready
Timer=0 : Status=0
If Timer > 1000 Then Error "Sensor Error"
OneWire Read PinTmp,4,1,Status ' Conversion status
Loop Until Status = 1
' Do
' 'Just pause for a second
' Loop Until Timer>1000
OneWire Write PinTmp,1,10, &H55,&H28,Ts1,Ts2,Ts3,Ts4,Ts5,Ts6,Ts7,&HBE
OneWire Read PinTmp, 2, 2, LTemp, HTemp
'Calculate the Temp in C
ReadTemp=((HTemp And &b111) * 256 + LTemp) / 16
' If HTemp And &b1000 Then ReadTemp=-ReadTemp 'Adjust if negative
If HTemp And &b1000 Then ReadTemp=(ReadTemp-128) 'Adjust if negative
' Print ReadTemp
' Print HTemp,LTemp
' Print Bin$(HTemp,8),Bin$(LTemp,8)
End Function
[/code]
This is the fragment that I have my doubts about.
[Code] 'Check sensor is ready
Timer=0 : Status=0
[/code]
Can't see what it's reading the status of, as far as the 6 sensors are concerned.
All have been initialised, and would all be active on the bus.
It's not until this point,
[Code] OneWire Write PinTmp,1,10, &H55,&H28,Ts1,Ts2,Ts3,Ts4,Ts5,Ts6,Ts7,&HBE[/code]
that the other 5 go offline, before the temperature is read.
[Code] OneWire Read PinTmp, 2, 2, LTemp, HTemp[/code]
Like I said, it's all working fine & has been for a few months, but I'd prefer it be correct & would like to correctly check for an unplugged sensor in a better way than just looking for -0.0625°C, because in reality that will be a true temperature reading during overnight temperature transitions.
Phil.
Edit:- Note there's a few things commented out, debugging etc ...
Edited by Phil23 2016-08-26
Phil23
Posted: 12:44pm 25 Aug 2016
I've been over the data sheet quite a bit, & mostly understand the commands, though it's a bit over my head in some areas.
I'm presuming when:-
read the scratchpad the reset at the end brings the others back online, but doesn't erase their scratchpads, otherwise the subsequent readins would fail when read from here in the main code.
[Code]Sub ReadTemps
TempAmb1=ReadTemp(TsAmb1)
TempRoof=ReadTemp(TsRoof)
TempLng1=ReadTemp(TsLng1)
TempBed1=ReadTemp(TsBed1)
TempOff1=ReadTemp(TsOff1)
TempOff2=ReadTemp(TsOff2)
End Sub[/code]
Phil.
