Forum Index : Microcontroller and PC projects : MX270 MMBasic Version
| OA47 Guru Joined: 11/04/2012 Location: AustraliaPosts: 1051 |
Could someone refresh my grey cells (I am thinking they are static and not dynamic), what it the highest version of MMBasic that will run on a 270 chip? GM |
Hi Mr Valve, I am not familiar with the '270 ever being used as an MMBasic form. (That is not to say it cant be flashed into a MX270) The Micromite started on the MX150 then the MX170. Now the MX470. Kind Regards, Mick Mick's uMite Stuff can be found >>> HERE (Kindly hosted by Dontronics) <<< |
Gday Mick, I not sure of the reference to valve, I thought I was a semiconductor. When Geoff originally did the MMBasic for the 170 chips I ordered some from MicroBlox but he mistakenly sent some 270's. At the time I wasn't to concerned as they would take version 4.6 with the only drawback of loosing 2 i/o's (the usb pins) I have a project that is using these chips and I would like to upgrade to use the power save feature implemented more recently. GM |
Version 4.5E for the PIC32MX150F128 chip also supports the MX250 chip. You can download it from here: http://geoffg.net/micromite.html#Downloads The latest version (V5.2) for the MX170 also supports the MX270. In both cases the USB functionality is ignored and you loose two I/O pins. Geoff Geoff Graham - http://geoffg.net |
Ok, Sorry Mr. Germanium Diode..
I went by your avatar without doing a Dr Google first... (Looked like a glass valve) I would suggest that you could use the latest 5.2 version in that case as the 250 was a 150 with the USB pins so I assume the 270 is a 170 with the two USB pins.. Mick Mick's uMite Stuff can be found >>> HERE (Kindly hosted by Dontronics) <<< |
Thanks Geoff and Mick. I will consider that my grey cells have had two refresh cycles. On the subject of valves, I remember them described as a GLASS ENCAPSULATED FET WITH AN INBUILT PILOT LIGHT. GM |
| LouisG Senior Member Joined: 19/03/2016 Location: AustraliaPosts: 130 |
A note about MX270 and MMBasic. If you try to use an MX270 in the Micromite Backpack you will get the MM prompt OK. But when you try to configure the LCD screen you will get > OPTION LCDPANEL ILI9341,L,2,23,6 Error: Pin 23 is invalid > Apparently Pin 23 is reserved for the USB port and is unusable. I found out the hard way when SC mistakenly included an MX270 chip with my kit instead of a 170. The 270 chip is otherwise quite usable. |
| twofingers Guru Joined: 02/06/2014 Location: GermanyPosts: 1773 |
From MMBasic User Manual (v5.2) page 5 Regards ‚My name is Ozymandias, king of kings Look on my works, ye Mighty, and despair!‘ Nothing beside remains. Round the decay Of that colossal wreck, boundless and bare The lone and ... |
Thank you twofingers I did look but I did not see it. (It seems to be a more common excuse these days) GM |
