Local Time 01:43 23 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Address a Bit in a Byte
atmega8
Posted: 10:03am 08 Sep 2016
Is this possible in mmbasic?
DIM A as Byte
Bit1 = Byte.1
Bit2 = Byte.2
Edited by atmega8 2016-09-09
Posted: 10:40am 08 Sep 2016
Not like that, but you can do things like
bitN = value AND (1 << N)
The parens aren't needed but I would say more readable.
(not tested, sorry)
Or simply
bit0 (bit1 if you prefer that terminology) = value AND 1
bit1 (bit2 if you prefer that terminology) = value AND 2
bit2 (bit3 if you prefer that terminology) = value AND 4
hmm, if you want them each to be 0 or 1 then you need more like
bitN = (value >> N) AND 1
JohnEdited by JohnS 2016-09-09
CaptainBoing
Posted: 12:53am 22 Sep 2016
Some code I use a lot... any use?
FUNCTION BitSet(value,bit)
BitSet=value or (2^bit)
end function
FUNCTION BitRes(value,bit)
BitRes=(value or (2^bit)) xor (2^bit)
end function
FUNCTION BitTest(value,bit)
BitTest=sgn(value and (2^bit))
end function
you then use it like:
flags=BitSet(flags,0) to set a bit in a variable
flags=BitRes(flags,0) to clear a bit in a variable
x=BitTest(flags,0) to test a bit in a variable
etc...
all the best
h
