Local Time 01:44 23 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Flash Write Error
MikeO
Posted: 04:17pm 19 Sep 2016
I am getting a Flash Write failure on trying to save a program. I had been successfully been running a program which had code in the Library and program memory. I had made a change in the Library code and went through the re flashing exercise and ended up with a CPU Exceptiona (a had a accent over it). Can't remember the exact sequence and point of failure as of course it was a surprise. It then went into a repeat cycle of
CPU exceptionà
CPU exceptionà
CPU exceptionà
CPU exceptionà
I had to stop it with the Shift! on reset. Then it signaled as below. It won't load anything into flash any more. I haven't tried yet to reload MMbasic but with the way it's behaving I wonder if its worth it, probably just replace the MX170 but it is a SOIC so will need soldering. Just wondered if anyone had experienced this.
Option error - Cleared OPTION TOUCH
Processor restarted
ÿÿýÿÿÿÿýÿÿýÿýÿÿýÿÿýÿýÿÿýÿýýÿýÿÿÿÿýÿÿýÿýÿÿýÿÿýÿýÿÿýÿÿýÿError: Flash write
Processor restarted
> memory
Flash:
0K ( 0%) Program (0 lines)
60K (100%) Free
RAM:
0K ( 0%) 0 Variables
0K ( 0%) General
50K (100%) Free
> Micromite MKII MMBasic Ver 5.2
Copyright 2011-2016 Geoff Graham
> option list
> XMODEM RECEIVE
Error: Flash write
> memory
Flash:
60K (100%) Free
RAM:
0K ( 0%) General
50K (100%) Free
Codenquilts
Posted: 04:42pm 19 Sep 2016
not wanting to sound like a broken record player, but check the capacitor on the Vcap pin. this the single most common cause of peculiar errors.
rob :-)
MikeO
Posted: 06:12pm 19 Sep 2016
Thanks, I will check the cap and the power supply, it could have absolutely suddenly failed but this circuit has been functioning for several months.
Codenquilts
MikeO
Posted: 07:23pm 19 Sep 2016
All working again.
I took it to the lab and checked power supply and cap, no issues there.
Uploaded and Ran a small clock program , print to console - OK
Set the options again for Display and Touch, Calibrated - OK
Ran a couple of Peter Mathers display demo - OK
Re install my software to library and main memory - OK
program ran - OK
I can only conclude some corruption with perhaps some connection too loosing the Options.Edited by MikeO 2016-09-21
Codenquilts
Posted: 09:02pm 19 Sep 2016
Mike
I've seen the same issue as well - in my case only reflashing cures it.
I haven't been able to tie down a cause but I think it is associated with a program load that has been interrupted or something like that
