Local Time 00:54 23 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Just a M or already a W?
Nathan
Posted: 05:11am 08 Oct 2016
please find attached a small demo for polygon drawing.
This version does not contain TTF memory read functions,
so it should run on the most tft displays.
rem **************************************************************************
rem *
rem * File: polygonDemo.bas
rem * Author: Nathan
rem *
rem * Created on 08. October 2016, 16:19
rem *
rem some buffer for the polygon definition and modification
Dim point%(polygonPointSize(14))
Dim pointX%(polygonPointSize(14))
Dim pointY%(polygonPointSize(14))
rem re2016-10-08_150925_polygon.zip set the point list
point%(0) = 0
rem polygonPointSet(<polygonArray>, P1x,P1y,P2x,P2y,P3x,P3y,P4x,P4y)
rem maximum of four points can be defines by single call of polygonPointSet
rem make a polygon last entry will be closed automatically
x%=polygonPointSet(point%(), 2,0,4,0,5,4,6,0)
x%=polygonPointSet(point%(), 8,0,10,7,8,7,7,3)
x%=polygonPointSet(point%(), 6,5,4,5,3,3,2,7)
x%=polygonPointSet(point%(), 0,7)
Rem for debug
Rem For cnt% = 0 To 12 Step 1
Rem polygonPointGet(point%(),cnt%,x%,y%)
Rem Print Str$(x%) + " " + Str$(y%)
Rem Next cnt%
cls
scaleX% = 1000
scaleY% = 1000
dx% = MM.HRES\2
dy% = MM.VRES\2
For outloop% = 0 To 4 Step 1
For angle% = -3600 To 3600 Step 10
REM polyRot(<inPointArray%>,<outPointArray%>,originRotX%,originRotY%,scaleX%,scaleY%,angle%,drawX%,drawy%)
REM processing order originRotX%,originRotY% -> scaleX%,scaleY% -> angle% -> drawX%,drawy%
REM Range: scale 1000 -> 1.0 angle -3600 to 3600 -> -360.0 to 360.0
polyRot( point%(),pointY%(),5,3,scaleX%,scaleY%,angle%,5,3)
polyRot( pointY%(),pointX%(),30,0,1000,1000,-3600+angle%*2,dx%,dy%)
scaleX% = scaleX% + 10
scaleY% = scaleX%
REM draw the polygon
REM polygon(<inPointArray%>,color%)
polygon(pointX%(),RGB(255,0 ,0))
Pause 100
REM remove te polygon (simple version for the moment)
polygon(pointX%(),0)
Next angle%
Next outloop%
print ".done"
Please find the recuired CSUB/CFUNCTION inside of th attached file.
2016-10-08_151110_polygon.zip
Nathan
Nathan
Posted: 08:45am 09 Oct 2016
I have a small update on the documentation
REM Range: scale[X,Y] 1000 -> 1.0 angle -3600 to 3600 -> -360.0 to 360.0
+ REM a negative scale is allowed and is equal to an mirror on X, Y.
Nathan
