Local Time 23:13 22 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Recursive Search MMBASIC
Yourock17
Posted: 10:34pm 02 Nov 2016
I was wondering if anybody has made/come up with a solution for Recursive directory search in MMBASIC for the Colour Maximite. I have attempted programming one but it doesn't output all of the files in the drive, just the first couple of files.
This is my attempt at one:
Do 'Go to root of drive
If Cwd$ <> "B:\" Then Chdir ".."
Loop Until Cwd$ = "B:\"
Dim DirVisited$(120) 'Define Directories Visited
'Count Files On B:
Print CLR$(2) Cwd$, CLR$(5) Directory$
Directory$ = Dir$("*.*", DIR)
1 Do
Count = Count+1 'Assign a number to a directory
If Directory$ <> "" Then 'If no sub directories then
If Directory$ = "." Then Directory$ = Dir$() 'Skip this
If Directory$ = ".." Then Directory$ = Dir$() 'and this
For Num = 1 To 120
If Directory$ = DirVisited$(Num) Then Directory$ = Dir$()
Next
Chdir Directory$ 'Change
DirVisited$(Count) = Directory$
Else
Chdir ".."
EndIf
Directory$ = Dir$()
Loop Until Cwd$ = "B:\" And Directory$ = ""
And this is it's Output (all directories in root sadly):
B:\
B:\PROGRAMS PROGRAMS
B:\RECOVERY RECOVERY
B:\SETTINGS SETTINGS
B:\USER USER
B:\WINDOWS WINDOWS
I would be very very happy, I have been trying at this one since around June.
Posted: 10:42pm 02 Nov 2016
Maybe someone already posted something?
I'm not quite sure what your plan for Cwd$ was but it looks not to have happened.
If you want to do a recursive listing I suggest recursive code because unrolling via a loop is faster but tougher to code (can be much tougher).
JohnEdited by JohnS 2016-11-04
twofingers
Posted: 12:32am 03 Nov 2016
My solution (not for a recursive search, sorry!).
(See sub ReadDir)
regards
MichaelEdited by twofingers 2016-11-05
The lone and ...
