Local Time 13:29 22 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MM2: webserver with AT mode ESP8266
Posted: 08:29am 07 Nov 2016
There are lots of versions of firmware for the ESP8266 but the simplest is the basic "AT" firmware provided by the chip maker Expressif. The firmware is included in the SDK (1.5.4.1) and can be flashed with their own flash download tool. Details for how to the flash the chip are in the documentation
Although there are easier ways of creating a webserver, using for example ESP8266Basic, the AT approach is easy to understand and seems very reliable (tested on Chrome, Edge and IE11).
The attached code is for a simple remote controlled thermostat but contains all the elements needed to set up the ESP8266 from "as-flashed" state and connect it to a router.
HTML requests are particularly verbose so I'm using a few of Geoff's excellent long string CFunctions that he includes in the Micromite distribution to allow strings over 255 characters to be parsed and/or printed
The key routines in the code are: Command, SendText and EndSend.
Command sends an AT sequence to the ESP8266. It includes a timeout and optional search string. In general AT commands indicate success with "OK" and failure with "ERROR". However, some AT commands report OK before completing execution so the optional search string allows you to wait for something other than "OK" to indicate completion. Command returns 1 if successful and 0 if an error or timeout has occurred. An example of using the function is:
[code]IF NOT Command("AT+RST", 10000, "WIFI GOT IP") THEN 'reset and check for valid connection[/code]
This resets the ESP8266 and waits for up to 10000 msec for the string "WIFI GOT IP" which indicates that the ESP8266 has connected to your network.
If this command fails the attached code includes all the commands needed to connect to the network from scratch
SendText does what it says. It sends a text string to the network. Typically this would be some HTML.
EndSend flushes the output buffer and sends the completion indicator which allows the page on the browser to complete.
In the attached code just change the constants
CONST SSID$=quote+"mySSID"+quote
CONST SSIDPassword$=quote+"mySSIDpassword"+quote
to attach to your router.
The code also includes a generic HTML request parser which should be generally useful
option autorun on
Option explicit
option default NONE
const MaxLen=4096
const max=20
' Global variables
const quote=chr$(34)
const starttext$="HTTP"
const pnf$="<html><body>Page not Found</body></html>"
const title$="<html><head><title>Remote Thermostat</title></head><body>"
const ending$="</form></body></html>"
const form$="<form name='f1' method='get' action='D'>"
const h2$="<h2 align='left'>Remote Thermostat V3.0</h2>"
const code$="Update Code: <input type='text' name='S' size='6' value='000000'><br>"
const tstart$="<p><TABLE BORDER='1' CELLSPACING='0' CELLPADDING='5'>"
const heat$="<TR><TD>Heating</TD>"
const hon$="<TD BGCOLOR='#ff0000'> On</TD></TR>"
const hoff$="<TD BGCOLOR='#00ff00'>Off</TD></TR>"
const tend$="</TABLE></p>"
const h3$="<TR><TD></TD><TD>Temperature</TD></TR>"
const s1$="<TR><TD>Current</TD><TD>"
const s2$="<TR><TD>Max</TD><TD>"
const s3$="<TR><TD>Min</TD><TD>"
const check$="<input name='C' type='checkbox' value='R' onClick='this.form.submit()'> Reset Max/Min"
const s4$="<TR><TD>Thermostat</TD>"
const s5$="<TD><input name='R' type='radio' checked='checked' value='"
const s6$="<TD><input name='R' type='radio' value='"
const click$=" 'onClick='this.form.submit()'> "
const degree$="°C<br></TD>"
const offstr$="Off<br></TD>"
const onstr$="On<br></TD>"
const ON=1
const off=0
' Set up parameters
const starttemp=20 'set the lowest temperature on the thermostat select radio buttons
const hysteresis=2 ' 2 tenths of a degree either side of the setpoint
const waittime=1000 'wait time in readrequest before timeout
const password$="123456" 'password to access change mode
const dspin=26
const relaypin=16
Dim arg$(2,max) length 20
DIM FLOAT inbuf(Maxlen\4) 'global input buffer
dim string CRLF=chr$(13)+chr$(10) length 2
dim integer IPDno 'global IPD numbers used to ensure transmit is on correct IPD
dim integer heater,currenttemp,maxtemp,mintemp,setpoint
dim integer nparams
dim page$ 'variables used by main loop only
DIM obuff$="" 'used to buffer writes to the internet to optimise speed
Init:
ds18B20 start dspin,3 'measure temp to 0.0625 degree accuracy
mintemp=1000 'set to silly value to force reset if not saved
maxtemp=-1000
currenttemp=cint(ds18B20(dspin)*10)
var restore 'recover the setpoint and min and max temps if already saved
maxmin 'update the maximum and minimum and save them if changed
heater=off
pin(relaypin)=heater
setpin relaypin,dout
setpoint=asc("E")
pause 2000 'wait for ESP8266 to wake up afer power on
open "com1:115200,4096" as #1
close #1 'clear the buffer
IF NOT Command("AT",500) THEN END
IF NOT Command("AT+RST",10000,"WIFI GOT IP") THEN 'reset and check for valid connection
PRINT "Set up WIFI on SSID: ",SSID$
IF NOT Command("AT+CWMODE_DEF=1",5000) THEN END 'set device mode (1=client, 2=AP, 3=both)
IF NOT Command("AT+CWLAP",30000) THEN END 'scan for WiFi hotspots
printlong(inbuf()) 'output the list of valid networks
IF NOT Command("AT+CWJAP_DEF="+SSID$+","+SSIDPassword$,20000,"WIFI GOT IP") THEN END 'connect
IF NOT Command("AT+CIFSR",5000) THEN END 'check IP address
ENDIF
IF NOT Command("AT+CIPMUX=1",5000) THEN END
IF NOT Command("AT+CIPSERVER=1",5000) THEN END
Print "Connected"
main:
DO
updateheater
if ReadRequest(waittime) then 'process HTML request
page$=ucase$(parsehtmldata$(nparams)) 'parse the html request and get the page requested
if page$<>"" then 'real request so do something
if page$= "INDEX" then
drawpage
elseif page$="D" then
if nparams<>0 then 'we have parameters to process
if arg$(0,0)="S" and arg$(1,0) = password$ then
if arg$(0,1)="C" and arg$(1,1)="R" then 'reset the max min to current
maxtemp=currenttemp
mintemp=currenttemp
var save setpoint,maxtemp,mintemp
endif
if arg$(0,1)="R" then 'change the setpoint and update the heater if applicable
setpoint=asc(arg$(1,1))
updateheater
endif
endif
endif
drawpage
else
SendText pnf$+crlf+crlf'invalid page
endif
EndSend 'clear the write buffer and terminate the write
endif
endif
LOOP
end
Function parsehtmldata$(paramcount as integer)
local a$,b$
local FLOAT buf(Maxlen\4)
local integer inpos,startparam,processargs
paramcount=0
inpos=SInstr(inbuf(),"GET /",1)
if inpos=0 then
parsehtmldata$=""
else
SMId buf(),inbuf(),inpos+5
inpos=SInstr(buf(),starttext$,1)
If inpos>2 Then 'page request found
inpos=inpos-2
a$=SGetStr(buf(),1,inPos)
inpos=Instr(a$,"?")
If inpos<>0 Then 'parameters found
processargs=1
parsehtmldata$=Left$(a$,inpos-1)
a$=Mid$(a$,inpos+1)
arg$(0,paramcount)=""
arg$(1,paramcount)=""
inpos=Instr(a$,"=")
startparam=1
arg$(0,paramcount)=Mid$(a$,startparam,inpos-startparam)
startparam=inpos+1
inpos=Instr(a$,"&")
If inpos<>0 Then
arg$(1,paramcount)=Mid$(a$,startparam,inpos-startparam)
a$=Mid$(a$,inpos+1)
paramcount=paramcount+1
Else
arg$(1,paramcount)=Mid$(a$,startparam)
processargs=0
EndIf
Loop while processargs
Else
parsehtmldata$=a$
EndIf
Else ' no page requested
parsehtmldata$="INDEX"
EndIf
endif
End Function
sub maxmin
local integer update=off
if currenttemp>maxtemp then
maxtemp=currenttemp
update=on
endif
if currenttemp<mintemp then
mintemp=currenttemp
update=on
endif
if update then var save setpoint,maxtemp,mintemp
end sub
sub updateheater
local integer hcalc
if setpoint=asc("L") then
pin(relaypin)=ON
heater=on
endif
if setpoint=asc("A") then
pin(relaypin)=OFF
heater=oFF
endif
if setpoint>=asc("B") and setpoint<=asc("K") then
hcalc=(setpoint-asc("B")+starttemp)*10 'setpoint temperature * 10
hcalc = hcalc + hysteresis
if currenttemp>=hcalc then 'turn heating off
pin(relaypin)=OFF
heater=oFF
endif
hcalc = hcalc - hysteresis - hysteresis
if currenttemp<=hcalc then 'turn heating on
pin(relaypin)=ON
heater=oN
endif
endif
end sub
sub drawpage
local integer loopcounter,tempconvert
local b$
sendText title$+form$+h2$+code$
sendText tstart$+heat$
if heater then
sendText hon$+tend$
else
sendText hoff$+tend$
endif
sendText tstart$
sendText h3$
b$=s1$+outtemp$(currenttemp)+degree$
b$=b$+s2$+outtemp$(maxtemp)+degree$
b$=b$+s3$+outtemp$(mintemp)+degree$
sendText b$
sendText tend$
sendText check$
sendText tstart$
sendText s4$
for loopcounter=asc("A") to asc("L")
if loopcounter=setpoint then
sendText s5$+chr$(loopcounter)
else
sendText s6$+chr$(loopcounter)
endif
sendText click$
tempconvert=loopcounter-asc("B")+starttemp
if loopcounter>asc("A") and loopcounter<asc("L") then sendText str$(tempconvert,2)+degree$
if loopcounter=asc("A") then sendText offstr$
if loopcounter=asc("L") then sendText onstr$
next loopcounter
sendText tend$
sendText ending$+crlf+crlf
end sub
function outtemp$(t as integer)
local integer tenths=t mod 10
local integer units= t\10
outtemp$=str$(units,3)+"."+chr$(tenths+48)
end function
sub printLONG(ret!()) 'used for debugging
local integer i%=Slen(ret!()),j%=1
DO
if i%>255 then
print SGetStr(ret!(),j%,255);
i%=i%-255
j%=j%+255
else
PRINT SGetStr(ret!(),j%,i%)
i%=0
endif
loop while i%>0
end sub
sub EndSend
local b$
b$="AT+CIPSEND="+CHR$(IPDno+48)+","+STR$(len(obuff$)) 'send anything still in the buffer
IF NOT Command(b$,500,">") THEN
if SInstr(inbuf(),"link is not valid") then exit sub
endif
IF NOT Command(obuff$,500) THEN END
IF NOT Command("AT+CIPCLOSE="+CHR$(IPDno+48),500) THEN
if SInstr(inbuf(),"UNLINK") then
obuff$=""
exit sub
else
end
endif
endif
obuff$=""
end sub
sub SendText(a$)
local b$
if len(a$)+len(obuff$)< 240 then 'add the new string to the output buffer
obuff$=obuff$+a$
else 'too big to fit so send the current output buffer
endif
obuff$=a$
endif
end sub
FUNCTION ReadRequest(timeout%) as integer
ReadRequest=0
SClear inbuf()
timer=0
do while TIMER<timeout% and LOC(#1)=0
loop
pause 200
if TIMER>=timeout% then exit function
do while loc(#1)<>0
SAddStr inbuf(),input$(min(255,loc(#1)),#1)
loop
if (NOT SInstr(inbuf(),"favicon",0)) and (NOT SInstr(inbuf(),"CONNECT FAIL",1)) then ReadRequest=1 'junk the favicon requests and disconnects
IF SInstr(inbuf(),"IPD,0",1) then IPDno=0
IF SInstr(inbuf(),"IPD,1",1) then IPDno=1
end function
end sub
FUNCTION Command(AT$, timeout%, other$) as integer 'send a command and wait for the answer
local i%=0,j%,ex%=0
Local a$
Command=0
SClear inbuf()
print #1,AT$+crlf;
TIMER=0
i%=0
do
if TIMER>timeout% then
ex%=0
EXIT DO
endif
j%=LOC(#1)
if j%>0 then
i%=i%+min(255,j%)
SAddStr inbuf(),input$(min(255,j%),#1)
if Slen(inbuf())>4 and other$="" then
if SInstr(inbuf(),"OK",1) then
ex%=1
exit DO
endif
endif
if Slen(inbuf())>7 then
if SInstr(inbuf(),"ERROR",1) then
ex%=2
exit DO
endif
endif
if Slen(inbuf())>len(other$)+2 then
if SInstr(inbuf(),other$,1) then
ex%=3
exit DO
endif
endif
endif
loop
select case ex%
case 0
Print "Timeout : "+AT$
case 1
Command=1
case 2
Print "ERROR : "+AT$
case 3
Command=1
end select
end function
function min(a as integer, b as integer) as integer
min=a
if(a>=b)then min=b
end function
CSub SAddStr float, string
00000000
10800011 00000000 10A0000F 00000000 90A30000 8C820000 00623021 1060000A
AC860000 24420004 00822021 24A50001 00831821 90A20000 A0820000 24840001
1483FFFC 24A50001 03E00008 00000000
End CSub
CFunction SGetStr(float, integer, integer) string
00000000
3C029D00 27BDFFE0 8C420040 AFB00018 AFA50010 AFA60014 AFBF001C 00808021
0040F809 24040100 8FA50010 1200001E 8FA60014 10A0001D 8FBF001C 50C0001C
8FB00018 8CA30000 5060001C A0400000 8E050000 00A3202B 14800017 240400FF
8CC60000 2CC70100 24A50001 00C7200B 00A32823 00A4302B 0086280A 10A0000A
A0450000 24630003 02038021 00452821 00401821 92040000 A0640001 24630001
1465FFFC 26100001 8FBF001C 8FB00018 03E00008 27BD0020 A0400000 8FBF001C
End CFunction
CSub SClear float
00000000 54800001 AC800000 03E00008 00000000
End CSub
CSub SMid float, float, integer, integer
00000000
1080001F 00000000 10A0001D 00000000 10C0001B 00000000 50E0001D 3C07000F
8CE70000 8CC20000 50400015 A0800000 8CA60000 00C2182B 14600013 24C60001
00C23023 240300FF 2CC80100 0068300A 00E6182B 00E3300B 10C00009 AC860000
24420003 00A22821 00861821 90A20000 A0820004 24840001 1483FFFC 24A50001
03E00008 00000000 03E00008 A0800000 1000FFE4 24E7423F
End CSub
CFunction SInstr(float, string, integer) integer
00000000
10C00002 00005021 8CCA0000 50800027 00002021 50A00025 00002021 90A90000
8C8B0000 01695823 016A102B 1440001E 008A2021 10000004 90AC0001 016A102B
14400019 24840001 90820004 544CFFFB 254A0001 51200010 25440001 00801821
10000006 24020001 90670005 91080000 15070006 24630001 00C01021 24460001
0049382B 14E0FFF8 00A64021 5449FFEB 254A0001 25440001 00002821 00801021
03E00008 00A01821 00002021 00002821 00801021 03E00008 00A01821
End CFunction
CFunction SLen(float) integer
00000000
10800005 00003821 8C860000 00C01021 03E00008 00E01821 00003021 00C01021
03E00008 00E01821
End CFunction
Edited by matherp 2016-11-08
nasi
Posted: 04:27pm 07 Nov 2016
Hey matherp.
So that web session I see above is that what you are accessing on the ESP8266 unit.
Gee I might skip straight to that instead all these other crazy things I had in mind.
It looks alot simpler for remote access of my controlled resources.
Might take me a bit to learn those CFunctions though.
Cool
Richard
Posted: 01:07am 08 Nov 2016
Here is the latest version with a BME280 used for inside temp/pressure/humidity and a DS18B20 used for the outside temperature
I've also connected the reset line on the ESP8266 to the Micromite to hold it in reset while the power stabilises.
Code attached
2016-11-08_110612_ATWIFI.zip
  Quote  Might take me a bit to learn those CFunctions though.
They act just like normal Basic functions and are fully documented by Geoff in the PDF in the Micromite distribution
nasi
Posted: 02:13am 08 Nov 2016
This is fantastic.
Opened up a can a worms for me there friend.
I so totally love this stuff.
Its exciting
Thanks MatherP
Richards
Posted: 02:26am 08 Nov 2016
@matherp
Excellent code once again from you which I have got my head round (most of it). Not yet tried it out for real so sorry if the following is a 'silly' question:
Can you enlighten me as to the functionality of the 'Update Code' input box on the browser end - thanks
Posted: 03:02am 08 Nov 2016
  Quote  Can you enlighten me as to the functionality of the 'Update Code' input box on the browser end - thanks
It is a security feature. Without knowing the 6 digit code you can't reset the max/min temps or change the thermostat setting. In the supplied code it is set to "123456" but should of course be changed before use.
CaptainBoing
Posted: 07:07am 08 Nov 2016
If you are doing WEB stuff, you might find these functions useful. B64is used a lot in HTTP for obfusctaion
Base 64 en/decode functions (not entirely my original work but can't find credit - sorry)
' needs OPTION BASE 0
CONST Mime$="ABCDEFGHIJKLMNOPQRSTUVWXYZabcdefghijklmnopqrstuvwxyz0123456789+/"
FUNCTION B64Enc$(x$)
LOCAL INTEGER c1,c2,c3,w1,w2,w3,w4,n
LOCAL STRING SO$
FOR n=1 TO LEN(x$) STEP 3
c1=ASC(MID$(x$,n,1)): c2=ASC(MID$(x$,n+1,1)+CHR$(0)): c3=ASC(MID$(x$,n+2,1)+CHR$(0)): w1=INT(c1/4): w2=(c1 AND 3)*16+INT(c2/16)
IF LEN(x$)>=n+1 THEN w3=(c2 AND 15)*4+INT(c3/64) ELSE w3=-1
IF LEN(x$)>=n+2 THEN w4=c3 AND 63 ELSE w4=-1
SO$=SO$+ME$(w1)+ME$(w2)+ME$(w3)+ME$(w4)
NEXT
B64Enc$=SO$+"=="
END FUNCTION
FUNCTION B64Dec$(x$)
LOCAL INTEGER w1,w2,w3,w4,n
LOCAL STRING SO$
FOR n=1 TO LEN(x$) STEP 4
w1=MD(MID$(x$,n,1)): w2=MD(MID$(x$,n+1,1)): w3=MD(MID$(x$,n+2,1)): w4=MD(MID$(x$,n+3,1))
IF w2>=0 THEN SO$=SO$+CHR$(((w1*4+INT(w2/16)) AND 255))
IF w3>=0 THEN SO$=SO$+CHR$(((w2*16+INT(w3/4)) AND 255))
IF w4>=0 THEN SO$=SO$+CHR$(((w3*64+w4) AND 255))
NEXT
B64Dec$=SO$
END FUNCTION
FUNCTION ME$(i)
IF i>=0 THEN ME$=MID$(Mime$,i+1, 1) ELSE ME$=""
END FUNCTION
FUNCTION MD(x$)
IF LEN(x$)=0 THEN MD=-1 ELSE MD=INSTR(Mime$,x$)-1
END FUNCTION
Used a lot when passing arguments and web resource names... converst stuff like %20%2e etc to the original characters
(this is my original work)
URLDecode function
FUNCTION URLDecode$(a$)
LOCAL INTEGER z
LOCAL STRING b$,c$
z=1
DO
z=INSTR(z,a$,"%")
IF z=0 OR z=LEN(a$) THEN EXIT DO
b$=MID$(a$,z,3)
c$=CHR$(VAL("&h"+MID$(b$,2)))
a$=Replace$(a$,b$,c$)
END IF
LOOP
URLDecode$=a$
END FUNCTION
VB Replace function
FUNCTION Replace$(a$,b$,c$)
LOCAL INTEGER z
LOCAL STRING x$,y$
z=1
DO
z=INSTR(z,a$,b$)
IF z=0 THEN EXIT DO
x$=LEFT$(a$,z-1)
y$=MID$(a$,z+LEN(b$))
a$=x$+c$+y$
z=LEN(x$)+LEN(c$)
LOOP
Replace$=a$
END FUNCTION
I have RC4 en/decryption functions if anyone wants them
my 2p
Edited by CaptainBoing 2016-11-09
nasi
Posted: 07:42pm 08 Nov 2016
Soooooo this would be harder or impossible for me to do on an older maximite with firmware 4.5E?
Richards
greybeard
Posted: 08:55pm 08 Nov 2016
Just do it all in the esp8266. You shouldn't need the maximite at all.
Plenty of examples out there.
nasi
Posted: 05:32am 09 Nov 2016
Yes I was starting to think that.
But I really love Geoff's MMBasic and all this work I have done already would be for nought.
But hey I think the coolest think about all of this is their is more than one way to skin a cat.
So to speak.
Richard
Posted: 07:33am 03 Mar 2017
In trying this very nice piece of software I was stumped for a while with this error while running on an Explore64 with MMBasic 5.3b:
Page$=UCase$(parsehtmldata$(nparams))
Error: Invalid syntax
I finally figured out that "Page" is now a command. Changing all instances to "pageX" fixed that.
Now I have an error sending the html back to the browser.
[code]
Opening COM3
Reopening COM3
Getting IP:
IP: AT+CIFSR
+CIFSR:STAIP,"192.168.1.201"
Connected
nparams: 0: |INDEX|
ERROR : AT+CIPSEND=0,173
ERROR : AT+CIPSEND=0,185
ERROR : AT+CIPSEND=0,238
[/code]
The first 6 lines plus the line after "Connected" I added for diagnostic purposes. Other than removing the calls to the BME280 (and setting appropriate values for data from it), I didn't make any changes to the parsing code.
I'm connecting with a ESP-001. The program says it has connected. In response to my browser request of http://192.168.1.201:1234/INDEX (which the line after "Connected" indicates id being received), I get "The 192.168.1.201 page isn’t working".
Anything to try to get past this sending error?
Edited by lizby 2017-03-04
Posted: 03:42pm 03 Mar 2017
This is perplexing. It works for me with IE, Opera, Safari, but not with FireFox or Chrome.
Edited by lizby 2017-03-05
Posted: 06:33am 04 Mar 2017
Ok, it was a rendering issue. Firefox considered the page to be text, and showed the raw html.
Chrome sent back to the ESP8266 that what had been sent to it was invalid, so I got the messages, "ERROR : AT+CIPSEND=0,239".
IE, Opera, and Safari figured it out and rendered the raw html appropriately.
Adding this line at the beginning of sub drawpage made it so that it works in all 5 browsers:
sendText "HTTP/1.1 200 OK"+crlf+"Content-type: text/html"+crlf+"Connection: close"+crlf+crlf
Posted: 06:48am 04 Mar 2017
Looks like they have changed something on Chrome. I did all my development using it and had no issues.
Anyway, very well diagnosed - sorry I couldn't help
Posted: 08:25am 04 Mar 2017
It may well have been a setting or an extension, but I have no idea where to look.
Sorted now, for me.
Posted: 04:50pm 04 Mar 2017
I note your use of these CSUBs and CFUNCTIONs:
CSub SClear float
They appear to use arrays of float to hold characters (bytes), and these functions operate in a similar manner to the similarly-named string functions.
Where are these CSUBs and CFUNCTIONs described?
Posted: 10:16pm 04 Mar 2017
These are provided by Geoff in the MM firmware distribution and there is a PDF in there (Embedded C Modules/longstrings.pdf) explaining their use
Posted: 04:16am 05 Mar 2017
Thank you. A very useful set of CSUBs and CFUNCTIONs.
And thanks for the ESP8266 code example. Got my own "drawpage" working now.
